Question about Hitachi C8Fse Sliding Compound Mitre Saw 216mm Blade 1050w 240v
I casnt remove the centre nut from my c8fse chop saw
  • 487 Answers
Hi, when I do this I insert a large screw driver into the blade saw to stop the blade turning, as you will need to turn the nut clockwise.
Posted on Aug 01, 2010
How do I change the saw blade in a Teledo TKZ 205 Chop saw
Using a set of vise grips clasp the blade so that the pliars get hung up on the blade housing/protector. Then get the correct size wrench and remove the nut and washer from the blade and replace it taking care to install it on the right side for proper cutting.
Sep 02, 2015 | Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How do you remove the blade on my toledo chop saw
Unplug the saw first. Then raise the guard and lower the blade onto a piece of wood to keep the blade from turning. Using a proper wrench, turn the nut in the direction the blade spins when cutting and remove the nut and blade.
Sep 04, 2014 | Saws
Cannot get saw to lift up on toedo chop saw
If your handle has two buttons, they are usually a power swtich and safety button so the saw isn't accidently started. No, power should not matter in the function of the swing arm. Most chop saws lock down by way of a small chain from the base to the end of the handle. Most miter saws and some chop saws lock down by way of a pin located on the pivot point of the swing arm. The pin locks the swing arm down by passing through a hole in the base pivot bearing.
Aug 17, 2012 | Saws
Cant remove chuck from a dwd 520
That one looks tricky! If the jaws on the chuck work lock an allen socket in the jaws and impact it of right hand with an impact wrench. This could damage the gears however if it's really tight. Another option is cutting half the chuck off in a chop saw just above the spindle and welding a nut on and impacting it off that way. The heat from the chop saw and welding will help loosen the chuck.
Good luck with that one!
Dec 28, 2011 | Dewalt Drills
Needing to change the 12 inch blade on a Dewalt chop saw. How do I remove theblade guard and remove the bolt out of the saw. Is the bolt clock wise or counter clock wise
I don't believe you have to take the guard off,just roll it back out of the way so you can get a wrench on the nut. The rotation is clockwise to take it off.
Aug 30, 2011 | Garden
How do you change a quik change chop saw blade
Loosen shield screw so you can tilt it up far enough to get to the arbor bolt. Set the arbor lock on the saw and remove bolt.
Feb 20, 2010 | Dewalt Chop Saw D28700
Grinding nuts
Try chopping the nuts first and remove them. Prepare the rest of the dish and add the nuts, mixing them in at the last.
Mar 18, 2009 | Hamilton Beach 70450 Food Processor
Hitachi C8Fse Sliding Compound Mitre Saw 216mm Blade 1050w 240v Logo
132 people viewed this question
Top Hitachi Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Hitachi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
