Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP 7310 Cartrige Belt Repair
My HP 7310 recently encountered a "cartrige jam" initiated by a paper jam which was corrected by removing paper from the rear. Somehow the black (or dark brown) thin "ribbed" cartrige belt became disconnected from the left side of the printer. The right end is still connected. I've been looking for an HP service manual on the internet but have had no luck. Any suggestions on how to fix this?
  • 1,218 Answers
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Posted on Oct 14, 2010
  • 225 Answers
The right end is connected with an idle pulley on a spring. If you grab the left end and pull it to the left, the spring will strech. This will help to attach the belt to the carriage motor on the left.
In some printers the spring streching is fixed by screw that have to be loosen first.
If you can't reach the motor's weel on the left, you have to take off some parts first.
Posted on Aug 01, 2010
HP 6500 Printer cartrige stuck on right side
unplug printer and plug the printer back in to see if it will try to initialize.
Jan 30, 2013 | Office Equipment & Supplies
When switched on indicates 'Clean Unable 46'
Issue with your Cartrige take off Cartrige then re-initiate setup
Check for back cover check for paper jam then re-initiate setup
If not re install Software ...
Sep 29, 2010 | Brother Office Equipment & Supplies
Paper jam at inner end of paper tray
Remove the cartrige and place the tray at the end of the printer then use small pillar to remove the paper
Oct 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
My officejet says insert cartrige in the slot to
It's not reading the chip on the cartridge. Push a wiggle it to see if it will make contact. Turn it off than on. if the chip is bad you will have to replace the cartridge again.
Oct 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam with a 4 x 6 paper
Remove the cartrige and remove the paper from the printer
Oct 16, 2009 | HP Photosmart C4280 Aio Printer
Hp photosmart 7760 print cartrige cradle is stuck.this happened after i ripped a paper jam out
try to move the cartrige cradle to left and right for about 10 to 11 times. if the issue still persist you may need to service you printer
Sep 27, 2009 | HP PhotoSmart 7760 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Cartrige Alignment
u can try the following steps .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Thanks
Apr 12, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
179 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
