I am having a problem connecting my power supply to my motherboard i can plug in everything except the one connectors that require a connection to a part called PWR-LED
  • 4,737 Answers
Take a look at the picture below:
If I am right, the Front Panel connector should look similar as shown above (it's an assumption since you didn't mention the Motherboard's name and version). Look at the front panel connector on the motherboard carefully, you'll see similar name/indicator as you are seeing on the above picture like Pled, Hdled etc... I hope the front panel connector has 9 pins, and remember, one should be left without any connection.
Simply you have to connect the two female Pwr-Led to the Pled+ and Pled-, and Power to Pwr and Gnd, the same sequence with hard disk led and Reset switch as Hdled+ and Hdled- and Gnd and Reset respectively.
If the front panel connectors on your motherboard has less than 9 pins, then I am sorry, I have no idea about it and I am afraid if it exists or not.
If you still have the problem, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 01, 2010
My desktop computer loses power when I plug the 4 prong power connector into the motherboard. I have tried a new power supply but it does the same thing
Maybe we need more information. The motherboard needs that connector. Is it disconnecting physically? Check the plastic clasp that hold it in place. Be sure the large ATX connector is connected properly. Unplug then plug it back in.
What do you mean by it loses power? Are the fans running when it is plugged in? Do the fans run when it is not plugged in? Try unplugging everything except your video card, CPU, RAM, and keyboard. Plug the ATX connectors in including the 4 prong one. If it still doesn't work check your capacitors. They are the cylinder looking cans soldered on the motherboard. Are they bulging or leaking? Might be time for a new motherboard. Good luck.
Feb 10, 2014 | Computers & Internet
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
Gateway T2838 with Intel 4000812 motherboard wouldn't power up. Replaced mother board and power supply. New components also won't power up. Both boards have green ready light lit on the board and both...
Check ALL your USB ports.. If any of the USB ports have shorted contacts or if the 5v rails are shorted to ground, the power supply WILL NOT switch on.. Also, if any of the items connected to the board have a supply rail grounded, again the board will not allow boot up. Unplug everything from the board and the drive power connectors too, except the power connector to the board and the front panel switches and try to switch on, if it still will not boot, check and recheck the USB ports and all power connectors, if it does, switch off and plug another item in, then switch on again. When you get to the item which prevents the board from switching on, thats where your problem lies. Dont forget, plug things back in one at a time, including the power plugs to the drives and try and power up between each item, and dont forget to power down after each item has been checked..
Mar 14, 2010 | Intel D845GVSR Motherboard
AOpen AX4BS motherboard front panel connections & power on.
That model motherboard does not support on/off control of the power supply. Refer to the output diagram on the power supply, and there should be pins in the connector (not used on your board) that may refer to the on/off control. Those pins should be tied together. Then the PC will turn on via the main power switch, and will require a manual turn off when the display says its ok.
Oct 24, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Two sets of power leads to motherboard from pwr pk, 1 x 20 pin and a 4 pin, when the 4 pin isn't attached to the 8s651mp-rz motherboard the fans spin, the mother board light comes on, but then does...
The 4 pin connector is required as it provides the power for the CPU to run. if nothing is happening with the 4 pin connector plugged in then there is a problem. You need to make sure that you Power Supply can supply enough power for what you are connecting to it (400W would be the bare minimum with no high end video card, 500W would be recommended). You also need to make sure that the Power Supply is connected properly because some Power Supplies from pre-built systems from companies like Dell are wired differently than the standard power supplies. The only other likely problem is that there is a short on the motherboard either from the mounting of the motherboard in the case or from something on the motherboard being bad. Make sure there is no metal touching the motherboard except at the holes used for mounting.
Jan 02, 2009 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Well my power suply fried and i got another one but when i turn it on the moniter says its disconnected i here the hard drives and all the fans r running what do i do
did you plug everything back to the new power supply?? is your monitor data cable connected properly??
please check everything is properly seated (don't assume... spend 5 minutes checking everything again) and make sure you GROUND YOURSELF by at least touching the power supply first before touching any component inside your pc.. don't forget to unplug the power cord from the power outlet!
some motherboard may have not only 1 but to power connectors, check your motherboard manual to ensure you're plugging everything that you need to plug (no more or less.. just about everything that needs to be plugged.. depending your motherboard and cpu power requirements.
check your memory is seated properly.
is your power supply of the same wattage as the previous one or larger? (if it's larger that's fine.. you gotta make sure you do have sufficient power)
Oct 05, 2008 | Computers & Internet
2 ATX POWER SUPPLY PLUGS
Some motherboard/cpu setups require an additional 4-pin connector for additional power on the motherboard. The motherboard will require either a 20-pin or a 24-pin power connector (main power), and might need the additional 4 pin as well. If the motherboard will accept the additional 4-pin, then connect it!
Sep 04, 2008 | Gateway GT4022 PC Desktop
DESKTOP COMPUTER TURN ON PROBLEM
In this case it is normally a voltage regulator near the cpu that is shorted and will need to be replaced.
Remove everything from the board, except the heat sink fan and plug in the big power connector, do not connect the 4 pin connector. Turn the power on as you were before.
Using a multimeter, check the voltages on those regulators. You should find them running in pairs normally, but make sure to check all of them and try to pick the odd one out.
Put your black lead to ground, and use some electrical tape to cover all of the red leads probe except for 2mm at the tip to help prevent shorting out anything else while you are there.
Apr 08, 2008 | Intel Motherboard
Not powering up
Did the CPU and cooling fan come pre-installed or did you have to install it? Did you forget the separate 4 pin power connector from the power supply to the motherboard? Is the speaker hooked up and are there any beeps? Do all the fans spin up? Do you have a video card that requires additional power connection and forgot to connect it?
Jul 08, 2007 | Foxconn 661FX7MI-RS (661FX7MIS)...
Motherboard
Katstu, Are any fans, hard drive or LEDs coming on at all, even briefly? If nothing try the following: -Check each screw, card, connector and component you installed to make sure nothings being shorted out or is improperly connected. Common occurrences are screws touching capacitor or other component leads. -Check the power connectors to make sure everything is connected correctly and that all the contacts are still mounted in the plastic connector correctly. -Check the output on your power supply and verify it?s rated for your motherboard. -Check the 110/220 voltage slide switch to ensure its on 110 (US). If the power supply has a rocker on/off switch make sure its in the on (1) position. -Make sure the motherboard is correctly grounded to the chassis per your instructions. Typically the mounting screws touch a grounding plane on the motherboard and in turn ground that to the chassis. If your using plastic mounting studs that might be a problem. -Verify the computer case power switch is working correctly. -Make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. If you get this far your processor or motherboard may be defective, it happens on occasion. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 11, 2007 | Asrock K7VM3 Motherboard
Computers & Internet Logo
223 people viewed this question
Alun Cox
David Payne
David Payne
