Question about IOGear GHD225U80 (DHGHD225U80) 80 GB Hard Drive
Computer does not recognise it. Device driver install failed.
  • 30 Answers
There are various possible reasons:
1. You may not be logged in as the administartor in the computer you tried using it it. ---When you are not logged in as the admin, you PC depending on the OS sometimes may not allow you to install any additional hardware.
2. There may be something wrong with either the device or the connecting cable. Try using the device in some other PC. If it does not work, try changing the connecting cable, if that does not work either, change the device. If it however does work with the same cable and device on another machine, then there may be a problem with your PC/OS. You should post this question again giving more info on the device and your PC and OS.
Posted on Aug 01, 2010
I HAVE NO DISC FOR MY WEBCAM IT GOT SLICED IN THE DRIVER,PHILIPSSPC630N/00
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Logitech QuickCam Communicate STX Personal...
Installed XP SP3 to my Dell 6000 and now NEC 6500a can't be found. Device manager says that the drivers are loaded by cannot find the hardward Code 41
see if its recognised in the Device Manager. Start/My computer/Control Panel/System/Device manager.
if so remove or uninstall the Drive.
Physically remove/eject the drive from the Computer. reboot then shutdown. re-insert the Drive. boot computer and see if it,s detected by the system or ( found new hardware Wizard )
re-install any drivers as requested. Installing SP3 shouldn,t do this. unless the drive was actually Virused Or failing already.
Mike @ compurepair.
Oct 16, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
IDT HD audio codec driver updated by windows updates. since this update i have no audio on my computer. It says device failed to start code 10 in control panel and the computer does not recognise any sound...
Go to the device manager and right click on the device and select properties. In the driver tab select rollback driver. This will install the previous version of the driver. Hope this solves your problem.
Cheers
Please rate!
Sep 28, 2009 | Computers & Internet
Sony K610i Will not sync with my computer
Please ensure that all drivers are installed. Check in device manager.
Right click on my computer and select properties. Then select the hardware tab and device manager in that section. If any drivers are not installed properly they will appear with a yellow exclamation mark. Reinstall these.
If all drivers are installed correctly check the contacts on the phone as sometimes the tend to get dirty and block the signal. also check if cable is faulty.
May 25, 2009 | Sony Ericsson K610i Cellular Phone
My computer does not recognise the device. What do
Did your camera come with an installation disk?
If so then install that or if windows ask you to install drivers do that.
If all else fails go to the manufactures site and look for any drivers or solutions there.
Apr 02, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
My friend just got a computer and he coud'nt download his games onto it and he could'nt get sound, so he installed a sound card which he says the computer recognised,but when he plugged in his speakers and...
PC does not recognise the card, You have to install the driver of the sound card. Right click on my computer and click Property and then click on Hardware and Device manager. If there is a question mark on the sound device than you have to install the sound card driver. A CD that comes with the sound card. Doubel click on the question mark and just read instruction and do installation. Is that answers your Question? Cheers
Dec 23, 2008 | Computers & Internet
DVD Drive not recognised!?!
control panel > system and maintenance > system
device manager
devolp + IDE ATA/ATAPI Controllers
reinstall device ICHx
Jun 03, 2017 | Artec DHM-G48 (ar16x) Internal DVD Drive
Speakers are not being recognised
i would like to know if your on board soud or sound card is not being recognized by your system? as far as i know speaker will not work if your sound device driver is not installed. so maybe theres nothing wrong with your speakers. try to go to my computer properties go to system device hardware and see if there is an yellow exclamation in your sound device. if there is, update the driver using the provided cd from your motherboard, if its on board sound device. but if its a sound card, update the driver using the cd provided from your sound card. but if your sound device is ok and there no yellow exclamation, probably you hooked your speaker connector to the wrong jack. it should be the color green one. try and good luck
Jan 20, 2007 | Generic Memory 2-Piece Amplified...
IOGear GHD225U80 (DHGHD225U80) 80 GB Hard Drive Logo
79 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
