Question about Dryers
How to I access the gas valve on my Samsung 419 dryer to change to LP ?
  • 10,865 Answers
Hello. It is code with all gas appliances that a shut off valve be located in the same room as the appliance. Carefully pull out the dryer and you ahould see the gas valve behind the dryer. If there is no valve there you will have to follow that supply line back until you find a valve. The worst case would be the valve at the tank. J.
Posted on Aug 09, 2010
Need some help to open a GE GFDS350 dryer to gain access to the gas valve to convert it to LP
Hi
Please check this video; though it is for gas valve coil replacement however, it gives you step by step instructions on how to access the valve:
Hope this helps...please post back for further assistance.
Daniel
Jun 30, 2011 | GE GFDS350GLWW Dryer
I bought a gas dryer how do know if it lp or nat gas?
LP has reversed threads which screw on the valve
May 20, 2010 | Whirlpool GGW9868K Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Mar 02, 2010 | Kenmore Dryers
How do you access the gas valve so the lp conversion valve can be exchanged...front of dryer or back, which panel do you remove
usually you can get to valve by removing front panal from dryer. if not take back of dryer off if need be.
Jan 14, 2010 | Washing Machines
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
SPEED QUEEN MODEL AGS68AWF-- I'VE CLEANED ALL VENTS. NOT GETTING HEAT.DRYER CYCLES BUT GAS DOES NOT TURN ON. I'VE OPENED BOTTOM ACCESS PANEL AND NOTE THAT THE IGNITER GLOWS AND CYCLES BUT GAS DOES NOT...
If the glow bar is cycling off and on the glow bar works and the black box on the side of the vent are working, Either there is no gas to the dryer, doubltful but something to check or, You need a gas valve.
I would check for gas first, do you have other gas appliances? and all are functioning properly? Check the gas line and make sure someone hasnt accidently turned off the gas. If it is none of these you need a gas valve.
Go to repairclinic.com or partselect.com with your Sp Q model number, or the part number off the gas valve, it could be a five digit 58**** or 51***** number. Get you best price. Im guessing 80 to 100 Amercian
When replacing the gas valve, unplug the dryer first, turn off the gas, remove the front panel, two screws lower front panel, you will need a crescent wrench for gas line of side and a 5/16 nut driver remove wires. Now remove the orfice from the old gas valve and make sure you install it on the new valve. Is this a Natural Gas or LP Gas dryer?, If it is LP make sure you make the conversion to LP. Ask if you have more questions on this.
install gas valve, tighten gas line turn gas on check for leaks! with a bubble solution, start dryer and make sure dryer works properly.
best of luck
T
Access to gas valve
I have the same problem ... please help me
Jul 04, 2008 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Jan 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Converting LP dryer back to Natural Gas
Hi, The Vent hole is usually on gas valves to make it universal for other applications requiring a vent. If there are no open holes on your gas valve this nut is not needed. You could contact a local appliance parts dealer with the mod and ser # on your dryer and just ask them what all is included in the conversion kit. You may even want to purchase a new one to make sure you did keep all the parts and you would also have new instructions for about $10-15. It would be better to be safe than to have to worry about burning your house down. With the LP parts you are taking out, Make some notes on what would need done to reconvert and fasten them inside the dryer access panel. NOTE: If this solution does not rate at least (almost there) please do not rate. Thank You, kstfas P.S. Gas companies are very helpful about checking things out for you because they are concerned about gas safety and their services are usually free.
Sep 26, 2007 | Cecilware GF-28 Deep Fryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Marvin
Marvin
