Question about Husqvarna Garden
Model HTC24 Flymo Hedgetrimmer
My Flymo Sabre Cut hedge cutter runs okay but will not cut any of the hedge have the blades come mis alinged
  • Husqvarna Master
  • 1,807 Answers
Are both the blades still moving? Are the blades sharp?
Posted on Aug 02, 2013
2 Suggested Answers
ianharper74
  • 5 Answers
SOURCE: flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Posted on Sep 09, 2011
Stihl HS 81 RC
You may be trying to cut material that is too large
Oct 05, 2013 | Garden
My flymo sabre cut keeps cuttn out every time the cord moves
Apparently you have some wiring issues ,that can be caused by the cord being stretched away from the handle...it can be rewired near the handle by someone with electrical knowledge,,,,,,must be familiar with electicity because of the power going into it by a home source and the hazzard of using it in damp or moist grass. shock hazzard
Jun 09, 2012 | Garden
I have a Flymo Sabre cordless hedgetrimmer, which has stopped cutting anything although the blades still move. What can I do to fix it?
If there are screws or bolts holding the blades together, check these are tight, but not tight enough that the blades can't move relative to each other. If the teeth aren't sharp, you can buy a small flat file to sharpen them. This is a tedious process and both cutting edges of each tooth need to be sharpened.
May 11, 2011 | Garden
Can I get my Ryobi Hedgetrimmer blades sharpened or replaced ? Its only 2 years old and blunt already, it struggles to cut conifer and tears rather than cuts. I am not impressed.
If the blade set is bolted together, then a local repair shop should be able to sharpen them. Look for a shop that works on Echo or Stihl hedgers, as they can be sharpened. If the blade set is riveted together, then it must be replaced as a unit. You did not list the model or item number for your hedger, but try www.ereplacementparts.com or www.ordertree.com . Both sites will allow you to type in your model or item number to look up all the available parts.
Sep 08, 2010 | Ryobi 18V Hedge Trimmer
Flymo sabre hedge trimmer blades move but do not cut!
Jul 23, 2010 | Garden
The cutting blades on my hedgetrimmer are not "crossing"
worm out bearing housing or eccentric lobes
no fix but a new head or unit
Dec 18, 2017 | McCulloch 18" Electric Hedge Trimmer
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
309 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
