Question about Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
When on filtration not a strong pump at all - Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
  • 8,404 Answers
Is this a 220 volt pump running on 110 volts? Check it out ...
If possible, you should run it on 220.
Posted on Aug 04, 2010
No pressure on gauge on filter pump
The same thing happened to me. So frustrating! I guess the pump that comes with the intex pool is not strong enough to do this. At least that is what I was told. So I just ended up sending that vaccum back and getting a catfish vaccum. Works great!
Jul 29, 2014 | INTEX Sand Filter Pump
Tip
Simple keys to a beautiful clean pool.
There are 3 keys to a clean swimming pool; filtration, circulation and chemistry. Not having the right amount of any one of these keys will soon cause the pool to be dirty. Filtration requires a filter that allows enough flow and catches any particles in the water. Circulation means enough water is circulating. Chemistry is having the chemicals to the right levels in the pool. The most important component to accomplish these keys is the pump. If the pump doesn't work then the filter doesn't work, the water is not circulating and since chlorine feeders need circulation to deliver enough chlorine to the pool, not having a working pump quickly causes the pool to go green.
on Aug 11, 2011 | Intex Easy Set Pool 15x36
Hi I have a balboa mgs504sz the pump runs constanly I've checked the setting by pressing the heat then pump button it's set at 2, it heats fine and seems to be working fine apart from running 24/7 any...
It sounds like you may be in standard filtration mode and you may want to change that to economy mode and then set your filtration times.
Jan 17, 2014 | Pool & Spa
What is the difference between a filter and a pump in a fish tank?
A filter maintains a natural environment that for fish thatbalances the good and bad bacteria in the tank. Additionally, a filter can remove toxins, chemicals and other unwantedmaterials from the water. The filterworks by taking water in from the tank and returning it clean.A pump is just a pump. It pumps air into the tank and creates bubbles, and sometimes a current. It does not clean the tank or balance thebacteria and PH like a filter does.
May 13, 2012 | Fish
On our Keys hot tub it is showing F8 along with the EC mode on the panel. We have had it 4 yrs and never seen this , It is also not shutting down all at once after the 2 hrs filtration. Any ideas? ...
The EC mode indicates Economy Heating mode. Which means it check the temp and heats the tub less often. The F8 is usually indicating Filter=8 hours of filtration. Change modes to standard, and change filtration to desired level.
If you do not have the manual for this tub, contact keys for instructions on how to change the filtration options. With out the model number I cannot guide you as to how to do this.
Jan 13, 2011 | Pool & Spa
If my pool has an algae problem now . can i convert to a saltwater filtration system w/o draining the pool ?
You need to rid the pool from algee. When you say saltwater filtration do you mean a chlorene generator? It generates chlorene from the sodium chloride that you maintain in pool. This still means you need chlorene to kill the algee. Shock the pool with chlorene shock. After allowing the pump filter to mix, let stand ovenight. Vacuum green slime from bottom to waste. Your pool supplier can help you . Kill the algee then start up chlorene generator.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
Installing an air pump in a 5000 litre tank
The pump must be mounted nearest the 5000 liter tank. The air intake will be the air sorrounding the area, while the discharge low pressure air must be pipe to underwater level such that the air discharge of the air pump bubble up the water (aerate the water) inside the tank. This is common in fish pond/ shrimps pond/ and water treatment plants. Electrical wiring is
standard for the electric motor and controls.
Nov 04, 2009 | Plumbing
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward Power Flo Lx 1 Hp Pool Pump Sp1580 Logo
105 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
