I own a Lennox model XC14-036-230, 14.2 SEER, 3 ton Elite condensing unit. This unit is less than a year old. Problem: AC unit will jump start during severe lightning storms, and it emits a loud "LOW" pitched noise. Note: During normal operation it emits a HIGH pitched noise.
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
  • 1073 Answers
SOURCE: we installed a 4 ton
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
Posted on May 08, 2008
  • 1073 Answers
SOURCE: air conditon units
the higher the seer the more efficent it is no matter the tonage of the unit
make sure that the tonage is correctly sized for the home rule of thumb is if the home is insulsted properly 600 sq feeet per ton
oversizing creates shot cycles real cool then warm real cool then warm, under size unit runs all the time
Posted on May 20, 2008
SOURCE: constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Posted on Oct 24, 2008
How to install condensation line on residential AC
Just get PVC 3/4 MIP fitting and enough pipe and elbows to run to drain. Glue together with PVC primer and PVC Glue.
Aug 04, 2014 | Carrier Comfort 3.0 Ton 13 Seer Ac Only...
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
Recently replaced entire central a/c - Removed 2,500 ton Rheem condenser - Unit is approx. 2-1/2 to 3 year old - 13 Seer - Interested in selling unit...Who made be interested in purchasing??? What would...
Hi, 2,500 ton unit would be the size of a 15,000sq.foot warehouse! I think you mean a 2 1/2 ton Rheem condenser. You could run an add under Craigs list.com, and if the unit is in good shape, I would ask no more then $600 for it. As a Contractor, I can get them anytime new for around $660.00. If you can get $500 for it jump on it. Best of luck to you,
Shastalaker7
A/C Contractor
Jul 26, 2011 | Heating & Cooling
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
Can you tell me the manufacture year and seer rating of a condensing unit with serial # 4397e02306?
Carrier puts this info or their data plates and have for a few years now. If it's not on this one, it's pretty old. If over 12 years, it will be around an 8 SEER or less. I you can supply a model number of the condenser I will be glad to look it up in my data base.
Oct 19, 2009 | Carrier Heating & Cooling
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
We installed a 4 ton downflow coleman air handler with evap coil Model number 1854s2m we did not change out the outside unit. the outside unit is a 13 year old 3 1/2 ton intertherm condenser the system is...
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
981 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
