Question about Briggs & Stratton Garden
Mountfield petrol mower HP470 problem with starting -I've checked plug and petrol both ok. It has a Briggs and Stratton engine. Ideas please. Thank you. '
  • Briggs & Str... Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times or spraying starting fluid into the carburetor, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
My lawnking Briggs and Stratton engine won't start
check you put it back together correctly including the cable and springs on throttle
Aug 04, 2014 | Briggs & Stratton Garden
My Briggs and Stratton lawnmower engine won't start. Checked for air, spark, and fuel problems.
Before doing too much more i would pull the flywheel off and check the key has not part sheared.
Jan 28, 2013 | Troy Bilt 5.5hp Self Propelled Mower
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
Cant get my mountfield lawn mower started, it is petrol and i have primed it by pressing the pump button as per the instructions on the mower. there doesnt seem to be any resistance when i pull the start...
make sure there is a spark plug in. that would be 1 reason why there is no resistance when you pull the cord. if there is a spark plug in then check to see if there is a clunking sound when you pull the cord if this is the case then the engine has a broken conecting rod..good luck
Apr 07, 2010 | Briggs & Stratton Garden
Bckfired, died and will not start.
Check the flywheel key. Sometimes a backfire can cause the key to break and the flywheel to lose its position on the crankshaft which will change the timing.
Aug 02, 2009 | Garden
What fuel do use in the mountfield HP470 petrol lawnmower is it a 2stroke mix?
No. This is a 4 stroke engine and it uses regular gasoline, not a mix.
May 06, 2009 | Garden
Garden Logo
1,164 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
