Question about Frigidaire ATF6000ES Front Load Washer
I have a front loan frigidaire that is leaking underneath i believe. I tried turning it on and seeing but now all the buttons turn green
  • 6,784 Answers
HI. In order to inspect for leaks, you will need to first locate the actual leak spot. This could be a damaged drain pump or drain pump hose connection. It could also be a failed bellow or door seal. Concerning the lights on the control panel; This could be the main control board signaling that there is indeed a pump issue or there may be an issue that concerns the integrity of the interface board itself.
With that said; I will need the entire model number that is associated with this unit. Once you have posted this much needed information, I will be able to post the proper service manual and proper directions that will help you solve this problem you are having with your unit.
Post the entire model number, asap..
Posted on Aug 01, 2010
My frigidaire dishwasher model #FFBD2403LW0B serial#TH13718959 leaks when it is running.seems to be leaking from underneath not from the front door.
how about putting the washer on some sort of stand so that you can look from underneath and then running it. use a light and observe where the leak is
Apr 11, 2017 | Frigidaire Dishwashers
Dishwasher leaking
If its leaking from the front its the seal. Its probably dried out and got a crack in it. You could try to repair it with superglue or something but would be best to get a new one (seal or dishwasher you pick)
Apr 18, 2014 | Frigidaire FFBD2406NB 24" Built-In...
Frigidaire washer repair
Hello Glenn Thompson - Where exactly do you see water leaking? Is the leaking coming from the front, in the back, underneath the washer? If I know more information on what the issue is, I can try to better assist your further.
Oct 11, 2012 | Washing Machines
Frigidaire washer leaking from underneath
Hello greschina - You would need to clean out the coin or filter trap to see if debris has clogged the drain lines.
1. Unplug the washer
2. Pull the washer out to tilt it back so you can reach the screws below the front panel and remove it. (You will need something to catch the water once the hose is removed from the bottom of washer).
3. Loosen the bolt with the sliver clamp on the bottom of the washer. The water will begin to come out while your loosening the clamp. (Do not remove any GREEN clamps).
4. Once the water is out, you can stick your hand inside the hose to clean it out.
Oct 08, 2012 | Frigidaire FAFW4011LW Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Leaking water on the front corner of the freezer side. We have turned off the water to the icemaker and have turned off the icemaker. Still leaking, not fast, but each day I clean up a puddle.
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket. Look in your freezer floor for ice build up. If you don't see anything like that or if you think the water is coming from underneath the fridge, then it is your condensate pan underneath. They crack sometimes.
Sep 06, 2009 | Frigidaire Refrigerators
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Washer leaks from underneath
It's still under warranty. Call frigidaire and find out who the closest servicer is. Or check this out: http://www.frigidaire.com/support/service_locator.asp
Oct 06, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
