Question about Kodak EasyShare C743 Digital Camera
Kodak C743 Battery Discharging When Switched Off
Hi, my C743 works fine with new batteries, but overnight the batteries are completely flat the next day, so I have to open the flap, but then I have to enter the date & time back in when I switch it on. Has anyone else reported this problem, it is quite annoying and I would like to know how to resolve it, please? Regards
  • 2 more comments
  • Repete01 Sep 02, 2008
    Yes, I insert fully charged batteries (...I even tried a couple of alkaline ones for a test) set the date and time, switch it off and in the morning the camera won't switch on, has lost the date and time and the batteries are completely flat.
  • Bullit-53 Sep 21, 2008
    I have the same problem. I have even tried Lithium batteries but these go flat overnight as well. The camera is switched off.
  • Anonymous Sep 26, 2008
    This happens to me too.
    I bought Kodak's rechargeable battery for the camera and I have to take it out when I'm not using the camera or it will die in the matter of a few hours. When I talked to Kodak about it, they said to update the firmware. My firmware has been up to date since I bought the thing and it still doesn't work. I don't use it often because of this.
  • cgmanimator May 11, 2010
    So you are saying you insert new batteries which are fully charged and overnight they are dead? Are you leaving the camera on and allowing it to auto shut off?
    Problem Solver:
  • 15 Answers
I would suggest, if under warranty, to take it back to the store or contack kodak for a replacement. Otherwise, start shopping for a new one. There are a ton of great digicameras available for the same if not cheaper than this one.
Posted on Sep 03, 2008
Battery keeps going flat
Check alternator voltage output, might be low. obd2 scanner
Jun 12, 2013 | Cars & Trucks
2007 Suzuki Forenza Replaced the battery a year and a half ago. Replaced it year and a half later. Week and a half later in the morning the battery is drained. Had the alternato, starter, and battery...
It would appear as though something is causing the battery to discharge - check things like the light in the trunk - make sure it turns off when you manualy simulate the lid opening and closeing. Also try disconnecting one of the battery leads then touch it to the terminal when everything is switched off - there may be a very slight spark because of the clock. If the "spark" looks much more then this proves something is drawing current from the battery which explains why it is discharging overnight. If you have after market hi-fi or any other toys then try disconnecting them if you see they are drawing power when everything is switched off.
Mar 18, 2011 | 2007 Suzuki Forenza Sedan
EasyShare C743 Digital Camera: I just bought a new 8 gig Kingston SD card for my ...
The C743 is only good to 2 GB other models of Kodak can use the larger cards but not the c743
May 17, 2010 | Kodak EasyShare C743 Digital Camera
I have a kodak c743 that won't power on. I have a new battery in it.
E-mail your question to this address:
Jan 09, 2010 | Kodak EasyShare C743 Digital Camera
I have an EasyShare C743. It just stopped working - I put in new batteries but nothing happens when I switch the camera on. What else should I be checking?
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 13, 2009 | Kodak EasyShare C743 Digital Camera
My Kodak EasyShare C743 digital camera goes through batteries like water. It's gotten expensive and the camera is so unreliable. Any advice would be very helpful! Thank you!
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
Jul 01, 2009 | Kodak EasyShare C743 Digital Camera
The rechargeable batteries last for about 1 min this is after being charged all night. what should i do? where is the reset button?
Rechargeable batteries do have a life, and it can be shortened with misuse. Order a new battery. Make sure to charge it completely before you ever use it. The first time you use it make sure you drain it completely before recharging it. This is vital to giving your new battery a good life.
Jun 23, 2009 | Kodak EasyShare C743 Digital Camera
All electronic devices will drain from the batteries connected, but overnight is ridiculous.
What are the features you want?
Do you want a point and shoot camera that fits in your shirt pocket or one that needs a carrying case?
I recommend a point and shoot for everyday picture taking, stay away from the non-standard cameras. Sony (R) is notorius for making proprietary devices that ONLY work with Sony. Which means that you have to pay more for Sony's proprietary converters to get it to work with your computer.
Purchase something with a not so large screen, to keep max. battery life. Also find a camera with a view finder. It may seem a little awkward having your face at your camera while taking photos, but we all did it prior to digital cams.
Search search search, until you find something you like and more importantly... can afford.
Sep 15, 2008 | Kodak EasyShare C743 Digital Camera
Camera Frozen in "On" Position
Hi, I read somewhere that this happens with alkaline batteries, but I have had the same problem with my rechargables (...don't use alkaline batteries in this camera). Anyway, removing the batteries with the camera in the off position and replacing them with fully charged ones usually clears the freeze. I also carry a spare CRV-3 just in case the rechargables go flat and this can help overcome the problem. Just don't leave it in the camera as they are too expensive to have it flatten them overnight!
Jul 05, 2008 | Kodak EasyShare C743 Digital Camera
My camera will not stay on
Hi Sarah,
I had the same problem. What I did was to remove then reinsert the battery and turn the camcorder on. I let the battery run down (discharge) completely, then plugged it in to the charger overnight. Doing a little more research on this camcorder, I found that if it hasn't discharged completely when you recharge then the battery holds less charge each time until finally you get next to no battery use. Discharging completely may be an option. Hope it works!
Oct 31, 2007 | Aiptek MPVR Digital Camera
Kodak EasyShare C743 Digital Camera Logo
282 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
