Problem with Annovi Reverberi RMV2.5G27D Pressure Washer Pump 2700PSI, 2.5GPM Ar
Pressure washer won't work.
My Annovi Reverberi Star Wash Prime 100 pressure washer has been working fine for years; now the motor just 'sounds' but will not build up any pressure.... any ideas please?
Posted by avatar on Aug 01, 2010
Suggested Solution (3)
your chemical feed works on most units on low pressure. there should be a adjustment nob red on the intake unloader. if not its preset
  • by Author image S Harlan Over a year ago
Source: How do you adjust the chemical feed on a Annovi
Was this solution helpful?
No
Yes
Your second tank is most likely for kereosene to heat the water....Check the manual from the manufacturer for sure
  • by Author image Martin Stevenson 186 days ago
Source: I have just inherited an annovi reverberi thunder
No
Yes
It sounds to me that you may have a broken piston ring. That would cause instanainious pressure loss. If not that it is a damaged seal between the high and low sides of the pressurized water. Good luck!
  • by Author image Ashley Helliwell Over a year ago
Source: won't build pressure
No
Yes
Tips for Helping john_sims2 With Their Issue
  • Give detailed step-by-step instructions
  • A picture or video is helpful
  • Use plain language not industry jargon
  • Check spelling & punctuation
Hide Tips
Add Your Solution
See all Annovi Reverberi RMV2.5G27D Pressure Washer Pump Problems
