Question about Dryers
Whirlpool LEQ9858PWO Ultimate Care II Dryer.The accudry function stopped working a few months ago and will not work when the start button is pressed. Now,the regular timed dry works for a short period and then shuts off. Not sure if it's a wiring problem or an overheating problem or something else entirely.
  • sjdebbie Dec 17, 2008
    I have the same problem with the Ultimate Care II dryer. I wrote and email to customer service at Whirlpool. It may be a switch that needs to be replaced. My dryer is 8 years old. Today got a response back - whirlpool_customerexperience@whirlpool.com - Due to our remote location, it is difficult to determine the exact
    cause of the problem that you are experiencing, and we do not have
    provisions for detailed technical assistance. We suggest for an
    accurate diagnosis and satisfactory addressing of any malfunctioning
    component that may be contributing to your concern that you contact our
    preferred service provider A&E Factory Service toll-free at (800) 771-3029.
4 Suggested Answers
  • 249 Answers
SOURCE: my Whirlpool Ultimate Care II dryer does not heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 02, 2010
  • 127 Answers
SOURCE: whirlpool ultimate care ii dryer, only works when
More likely than not either the start/run switch on your motor wen't bad, or the motor windings itself. Either way you need to replace the motor #279827 around $100 on up.
Not tough to get to if you know how to gain access to the cabinet, just remember that the blower wheel and motor threads going into the blower wheel are LEFT hand thread,
have fun, and best of luck,
ttfn
Posted on Feb 04, 2010
heatman101
  • 43501 Answers
SOURCE: Whirlpool AccuDry Ultimate Care II
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Jul 24, 2011
TheMobilian
  • 8205 Answers
SOURCE: Whirlpool Ultimate Care 2 LEQ8000JQ3 w/ Accudry- how do I make sure the Accudry feature works properly when I replace element?
The orange wire mounted to the 250 limit at the base of the heating element connects to the timer motor. When the element is on the motor cannot move forward in autodry. When the element is off the timer motor slowly advances. that is how it works. If you small limit on top is blown you have a restriction in your venting system or a clogged filter chute or a bad cycling thermostat. I worked on one and did a video recently. ROPER DRYER NO HEAT VIDEO
Posted on Jul 08, 2012
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Jul 08, 2012 | Whirlpool Dryers
    Whirlpool AccuDry Ultimate Care II Dryer will heat up
    heatman101
    Jul 17, 2011 | Dryers
    Whirlpool ultimate care ii dryer will not stay on when start is pressed
    if you push the start button an as soon as you let go of the start button your dry stop you need a new motor
    Apr 24, 2010 | Whirlpool LER4634J Electric Dryer
    Whirlpool ultimate care ii dryer, only works when continuosly pressed the start button. What can be the problem. whirlpool ultimate care ii dryer model gew9878lw0
    ttfn
    Feb 04, 2010 | Whirlpool Dryers
    Washing machine starts by itself
    going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
    Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool dryer
    is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
    Mar 11, 2008 | Whirlpool GEW9250P Electric Dryer
    Dryers Logo
    451 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
