Question about Masterbuilt ESQ30B Smoker
Fuses blow keeps blowing fuse when plugged in and powered on. Sometimes can get to run for a while then pops the circuit. Tried different outlets and get same result
Mr. heater big maxx keeps blowing fuses, Replaced everything in it and still does it. sometimes it will run for a while
Maybe its the wire or the outlet. Does the wire get hot? Try a different outlet that is on a larger amp breaker.
Dec 07, 2016 | Mr. Heater Heating & Cooling
My 2008 suzuki grand vitara keeps blowing the fuses for the ACC outlets. both are 15AMP, but even with nothing plugged in, nothing down in the outlets and even with larger AMP fuses, they keep blowin
If you use too large a fuse, the wiring can catch on fire, and the whole car could burn up. You'll need an auto electrician to trace that problem. You can remove any bulb and unplug any device that is on the Acc(essories?) circuit; then see if a fuse will stay; start replacing items till you blow the fuse. It seems like a dead short which can surely melt wires if you keep taking chances. good luck.
Feb 14, 2015 | 2008 Suzuki Grand Vitara
Dodge radio problems
fuses blow because of excessive current flow from a dead short to earth. You haven't stated which fuse blows and what the items are covered by that fuse. so check the power wire from that fuse and trace it until you find a burnt area or a place where the power wire is touching the body before it gets to something it is running
Dec 22, 2013 | Cars & Trucks
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
All power outlets went out. I replaced the fuse in the side panel but, as soon as I plug anything in, I can hear the fuse pop. I have checked all the other fuses andit is the only one that is blown.
You will need a new power outlet / cig lighter socket. The side tabs can get bent, and it will internally short and blow the fuse, whenever something is installed. Visually look inside the socket to see if the 2 side tabs (ground) are bent inward or downward. The center dot at the very bottom is the power, if it touches the sides or the tabs it will blow the fuse. It could also be the appliance you are plugging in, try something different (like a phone charger).
Apr 08, 2011 | Dodge Durango Cars & Trucks
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
1700 watt fog machine keep tripping GFC and blowing fog machine fuse
the fog machine needs to be on a dedicated line because of the wattage it does and the amp is rated as a 15 means the circuit breaker on this line needs to be 15 min safe at 20....
the fog machine is like a mircrowave and any major appliance needs dedicated lines not shared with lights or outlets besause it draws a lot of power to start and run and depends how long watts is simular to power the more light bulbs connect to a circuit breaker adds up 4 75w light bulbs adds up to 300 watts and that not includling outlets that may be connected....
not a gfci Unless dedicated at 20a....
Oct 17, 2008 | Kitchen Appliances - Others
Nad 218 thx power amp keeps blowing ac plug fuse
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Apr 27, 2008 | Audio Players & Recorders
Tv keeps blowing fuse when plugged in
do not put another fuse because there is a shorted in either the power supply circuit or the horizontal deflection circuit. in power supply try to check the rectifier, filter capacitor, or the regulator ic/transistor. in horizontal, try to check the horizontal driver/ output transistor or the flyback transformer. good luck! but if u dont know anything about this much better to bring it to a qualified service technician. good luck!
Feb 01, 2007 | GE 31GT660 TV
Masterbuilt ESQ30B Smoker Logo
196 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
