Question about HP Photosmart 8150 InkJet Printer
Error message on photosmart 8150
Error says cartridge service station is stuck. I think I have a part that is supposed to be somewhere on the left side of the printer - inside - can I take it apart to check it out? I had a paper jam and cleared it and then unplugged to clear go and still have this extra piece.
  • 36 Answers
Well, what you want to do is you will see a wire coming from your cartridge, pull that wire (not hard) just so that way you can move the cartridge and you should be able to fix that problem.
Posted on Apr 25, 2008
It is giving me an error code OXC18A1502
it is 100% mechanism issue but you need to identify weather the printer head is in struck in left side[service station] or right side..
if it is struck in service station, you need to replace or reinsert the service station....
May 06, 2014 | HP Photosmart C7180 All-In-One InkJet...
Printer hp 8150 messages says cartridge server station stuck
Technical skills required to do this process, remove top,side doors, un lock carriage from service station, remove service station, clean & lubricate it for free movement, fix it back. try for print.. this is only solution for this issue, but mind that its dirty work...
Jan 04, 2012 | HP Photosmart 8150 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Fast blinking red light, message says cartirdge service station is stuck
Follow these instructions to adjust the clutch on the printer.
Disconnect the USB cable.
Press the printer power button to turn off the printer.
Disconnect the power cord from the back of the printer.
Open the top cover of the printer.
Remove the print cartridges from the printer.
Slide the cradle to the right side of the printer.
Locate the clutch on the left side of the printer.
NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal.
Figure 1: Printer clutch
Remove the rear access door from the back of the printer.
Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
Release the clutch and roll the wheels up two more rotations.
Reinstall the rear access door.
Reinstall the print cartridges and secure the latches in place.
Close the top cover and reconnect the power cord.
Turn on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
How do I free a stuck cartridge service station.
These are generally pretty easy, they are supposed to move to the center whenever you open the lid. However, there are quite a few things that can stop this from occuring,
If you have a print job in the que, or a camera card in one of the readers it needs to finish what it has qued before it can continue.
Remove any camera cards, close the lid and power down your computer. Then turn off the power to the printer. Remove the printers power cord and wait thirty seconds. Plug it back in and give it a minute to get through it's warm up. While it's warming up listen for the normal sounds of the head moving back and forth.
If you don't hear the sound it's likely a mechanical failure in the printer, if you do when you open the lid now it should move to the center to allow you to load the new ink.
If it doesn't you can post back here for additional info or go to:
enter the chat with an online hp support tech as they have more detailed info for you to diagnose the issue.
Hope this helps FixYa,
May 05, 2009 | HP Photosmart 8150 InkJet Printer
HP 8150 Wont Print in color
Hi i have simular problems i think. i did getting a fault on my cartridge and the fault message i getting tells me that something is wrong with cartridge and printer will print in backup mode by takeing away the black cartridge, i did try to change to a new black cartridge and the same problems appear.
After some investigating of this problem it seems to be a kind of delikat on my printer, inside where the black cartridge should be placed there are a metall "feather/spring" this has losen at one time i dont know when. but this sharp metall "spring" have been pushed in when replacing cartridge and made a hole in white elektrical connections for this particular cartridge and may damage this connections, maybe this has happend with yours printer as well.!?
And know how to fix this, with no support left at HP there arent so much to do i believe i have to use cartridge with triple color or trow this one away and buy a new one. Use and trow away with blessing from HP.
Aug 26, 2008 | HP Photosmart 8150 InkJet Printer
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Error message
hi good luck
May 03, 2006 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart 8150 InkJet Printer Logo
211 people viewed this question
Ben Johnson
