Question about Nvidia GeForce FX 5500 Video Card Graphic Card
D C BORD SHORT - Nvidia GeForce FX 5500 Video Card Graphic Card
    President:
  • 2,571 Answers
If it has a short, you may as well get a new one if you cant repair it yourself. It would cost more to fix than its worth
Posted on Aug 01, 2010
SamsungE1410 bord shart how to remove
If your mobile motherboard short.. You can remove easily.. Connect full charge battery in short bord then if any component heat remove tha component or remove flirting capacitor on voltage path
Aug 26, 2014 | Samsung Cell Phones
What is the procedure for nokia 5200 dead set checking?
NOKIA 5200 DEAD WITH OUT ROUGH HANDLING
..open the hand set carefully
..clean the Bord very well with liquid cleaner
..then heat the Bord with a blower
..then try reassembling the hand set
..power on and check
**it could be possible that the water vapour might have entered the hand set causing pin to-pin shorting of the relevant ics on may be some components might have loose solder***
NB..if the solution is helpfull, you can thank me by emailing me back
Jul 01, 2014 | Nokia 5200 Cellular Phone
Mother board short
MOTHER BORD SHORT
Aug 21, 2013 | SAMSUNG GT E2652
MY 2001 VW CABRIO GUAGES ARE FLICKERING AND NOT WORKING PROPERLY FUEL,TEMP,SPEEDO,TACH WHAT CAN I DO
the case you have disconnect on the ground ( brawon coler) inthe claster . all guage have one ground check the braown coler wire but don't remove or disconnect the calster it may lose key prog try disconnect battarry then check from guage bording up to dash bord bracket . try make sure you have no short with any sender ( fuel .tem. or speedo)
Jul 27, 2011 | 2001 Volkswagen Cabrio
Clicking - Freezer section problem...
could be the bord but my bet is its the fan motor,,,it has a short in it,,,try unhooking the fan motor from the bord and switching it on, if the bord stayes switched on,,, its the fan motor faulty
Jul 10, 2010 | Hotpoint HSS25GFP Side by Side...
Why does my washer stop midway through the cycle and continue beeping?
p.c.b bord faults detect shorts and beep to warn the owner that there is a fault the fault would be in your upper or lower p.c.b bord
Jul 06, 2010 | Washing Machines
PC wont power up after replacing the Power Supply and MOBo
hi swich off pc & remoove power card from smps. short Bios jumper
on mother bord.(locate that jumper, lift ,short with 3rdpin &replace it as old position.
now switchon pc.
r u connect cpu core supply voltage on mother bord ?
tell me
Aug 07, 2008 | Gateway Computers & Internet
Er8000
good evening ! i`m sure that your encyclopedia er8000 is shorted try to cleaning the mother bord or bring it to the repair shop to clean and to test the bord !thank you !good luck and god bless you !...
Jun 08, 2008 | Seiko Britannica Concise Encyclopedia...
My motorola turns on but for only about 3 seconds then turns off or frezes
you CAN...i dont know where to get one...try ebay for a parts phone, like one that has been broken in half but still works
Aug 03, 2006 | Motorola Mobility RAZR V3
Nvidia GeForce FX 5500 Video Card Graphic Card Logo
29 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
