Question about Hayward SAND FILTER, PRO SERIES
The handle that turns to backwash has broken off ,can this valve be purchased
  • 8,404 Answers
Multi Port valve handles and Push Pull valves are both available at your local Pool Professional supply place.
Posted on Aug 01, 2010
Old triton pool sand filter....2 orange valves.. What is the position for filtering and backwashing?
orange valves are for the returns the backwash is the skinny rod with the black handle check flow of pool I think up is backwash down is filter
Sep 09, 2015 | Pool & Spa
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
What i she sequence when backwashing---Backwash - Rinse - Wash ? I have a Vari Flo
Backwash until water in the sight glass is clear, shut off the pump and change the valve setting to rinse, turn the pump on for a couple seconds and then back off, change the valve setting to filter and return to normal operation. NEVER move the valve handle while the pump is on.
John
May 05, 2011 | Hayward SAND FILTER, PRO SERIES
Sand and murky water being discharged into pool after backwash
You posted this question in Alarm category. but sounds like either your filter laterals, or the backwash valve are bad. I'd need to know what type of filter, and backwash valve you have. is the backwash valve a multiport, or push/pull slide valve, etc... If it's a push/pull valve then the o-rings, or pucks can be bad, or the piston can be broken. if it's a multiport valve, then the spider gasket may need to be replaced. if it's a top mount multiport valve, then it can be broken inside the filter.
Aug 16, 2010 | Pentair Pool & Spa
Lost manual and forgot how to backwash filter.
Shut off the pump, press down and rotate the valve handle to point to the backwash setting. Turn pump back on and run until water coming out is clear. Shut off and rotate handle to rinse setting, turn back on and run for 15 seconds. Turn off and rotate handle to filter and turn back on.
Apr 11, 2010 | Hayward Pro Series 18" Above Ground Pool...
Water still flowing out waste when filter is in filter mode.
The gasket inside the valce is either out of place or damaged. You can rebuild the valve with a gasket set. For a quote on the repair kit, send your valve model number using our contact form at www.arrowpools.net and we can identify the correct kit for you.
Jul 12, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
How do I backwash my Pentair Vertical Grid DE filter?
For instructions on backwashing and other trouble shooting, you need an Owner's Manual. You can find one online at the following link:
http://www.pentairpool.com/pdfs/FNSPlusVerticalGridDEFilterOM.pdf
The way you backwash this filter is easy once you get the hang of it!
The first thing you will do is turn off the system, change the valve position to the Backwash position. If you have a Multiport Valve, you will press down on the handle and spin it so that the knotch is pointed to BACKWASH. If you have a Slide Valve, only has two positions, up and down, you turn the handle so that the metal pin is out of the holder and move the handle in the opposite direction. You will need to turn the handle to lock the pin into position.
Once this is done, you will turn on your pump. Pentair recommends that you backwash for 1 minute, then turn off the pump.
If you have the Slide Valve, you will put it back into the FILTER position and then turn the pump back on for 1 minute. If you have the Multiport Valve, you will put it in the RINSE position and then turn the pump back on for 1 minute.
Pentair recommends that you do this cycle a total of three times, backwash/rinse, backwash/rinse, backwash/rinse. AFTER the third time, you will need to open the Air Release Valve at the top of the filter while the pump is OFF and the valve position in back on FILTER. Once this is done, turn on the pump. When you have a steady stream of water coming out of the Air Release Valve, close that up. This way you have no air in the system.
Now, you will mix your DE "Slurry" in a bucket. Depending on your model of filter, you will measure out your DE and mix with water to the consistancy of milk. **IF it is just a backwash, you will only add 80% of the original amount of DE. You only add the total 100% of DE when you completely take the filter apart and clean it out.**
You will slowly pour the slurry into the skimmer that is closest to the pump. This will allow the DE to evenly coat the grids in the filter. Wait about 5 minutes and then check the pressure gauge on the filter. Once the PSI reaches 8 to 10 PSI above this number, it is time to backwash.
Jul 09, 2009 | Hayward EC-40 DE Pool Filter with pump
Water dripping out of backwash port when handle is on filter
You might have it overfilled with sand. It's getting into the seats of the valves.
Jun 20, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
501 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
