Question about GE (PSS26MSRSS) Side by Side Refrigerator
A loud buzzing sound coming from the freezer - GE (PSS26MSRSS) Side by Side Refrigerator
  • 10,515 Answers
Provide some more details :-
1. Is that continuous or intermittent?
2. Could you narrow down the noise? Are you sure that it is no where from or around the compressor?
Thanks!!
Posted on Aug 01, 2010
  • 1 more comment
  • fourthdownen Aug 01, 2010
    It is continuous but gets louder at times
    where is the compressor
  • taran_2005
    taran_2005 Aug 01, 2010
    Thanks for your response!!
    Unplug the refrigerator or turn off the breaker that powers it. Since
    you will have to get to the backside of the refrigerator anyway, I would
    recommend you unplug it.At the bottom rear of the refrigerator you will see a large cylindrical object. That is the compressor.
    However, i would recommend a technician to fix this as it could be dangerous, if proper precautions are not taken.
    If your hear humming / buzzing sound from or around the compressor , and you wanted to repair it, revert and i would be able to give you some pointers.
    Good Luck!!
    Thanks!!
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Loud buzzing from freezer
icemaker wont work in fridge. the buzzing sound might be the water solenoid operating and waiting for water level sensor to be happy. solenoid will make a loud harsh buzz check water supply to back of freezer and see if there is a lever on icemaker you can lift up to turn off.
May 16, 2013 | Frigidaire Professional 27.8 Cu. Ft....
Loud buzzing noise and not cooling
When you say buzzing sound is the sound coming from the back? If so either the relay overload in the compressor has gone bad or the compressor itself. The part number for that is going to be Pt# 8201786. Now if the sound is coming from the inside of the freezer something may be obstructing the evap. fan motor and not allowing air to circulate.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | Whirlpool ED2SHAXM Side by Side...
My JMB fridge freezer is not working
usually if the buzzing sound is eminating from the compressor it is a defective compressor and theres no fix except to replace it
Apr 26, 2012 | Refrigerators
After loading freezer a loud buzzing sound started
Is it coming from inside the freezer or outside? If outside either the auto defrost timer is a problem. If the noise comes from the compressor, almost certainly the starter relay inside the electrical cover needs to be replaced. It can be purchased at most refrigeration outlets. If coming from inside, you need to defrost the freezer properly for 12 hours then restart. The noise should go away then.
Jun 12, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerator is making a loud buzzing sound in the freezer compartment. We did see a Er FF error on the display. We cleaned out any extra ice/frost buildup and then reset the breaker. The display no...
check your evaporator fan maybe the fan blade hitting edges or the shaft or bushing has damage cause of buzzing sounds apply lubrication or replace bushing but before you dismantle try to off the unit.
Feb 20, 2011 | LG LFX25960ST Stainless Steel French Door...
Freezer ajar loud noise
Yes Evaporator fan that has ice accumulation in it. Turn off the unit and leave the freezer open for about an hour or two re-start it and hopefully the frost that built up from the freezer being ajar will have thawed and melted away.
good luck to you!
Jun 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
The Top Freezer Is making a Loud buzzing Noies!
Hello psimmons304,
Yes it does sound like a issue for the fan. What i would do is look up the model on google and type in replacement fan. you should be able to find it that way.  If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | GE Profile Arctica Stainless Steel Top...
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
21 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
