Question about Dewalt DC330K XRP 18v cordless Jig Saw Kit with All - Metal Keyless Blade Change
Jigsaw keeps jumping during cuts. are there any adjustments?
Blade is to short or teeth are to big
Posted on Dec 29, 2012
How to lock the jigsaw blade to make straight cuts on my Boschest 1587svs?
Use a straight edge guide. Clamp it on the work so the jigsaw can run against it. Be patient and go very slowly.
Mar 04, 2017 | Blade Saws
The blade on my jigsaw keeps flying out when i try to cut wood ive inspected the the place where the blade goes looks ok please help
There are diffrent blades for difrent makes ,Did you by the correct make e.g if its bosh by bosh blads .The slot might also be worn out if you used the wrong blade in it or the screw that holds it in is warn ,Hope this helps
Oct 01, 2014 | Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
I have a craftsman jigsaw(scroll) that I got for Christmas last year. The blade comes out in the middle of my cut some time. Is there a problem with this type of jigsaw?? I have sanded the top of the...
Most of the time the cause for this is applying to much pressure on the blade as you are cutting. Remember, the blade does the cutting and you are guiding the jigsaw around the cut. This can strip the blade and wear the top of the mount. Adjust the way you cut and you should not have any problems.
Aug 26, 2011 | Craftsman Saws
I have a Bosch Jigsaw Xcel PST. I purchased the Jigsaw about 6 years ago but it has not been often used. Recently the blade will not lock into and remain in position for cutting. I cannot find my manual...
You will need to obtain a new [Roller Lever Assy] from a Bosch parts dealer. Its a fairly simple install. This is a wearable part due to the pressure put on that portion of the tool during normal use.
Feb 07, 2011 | Bosch Garden
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
Blade keeps on jumping out during sawing.
You are not actually tightening the blade in place. The only orientation is front and back, but I suspect that you knew that...
Sounds like you are not actually tightining the blade.Pull up HARD on the quick release knob or it will not actually engauge, but it will sound like it is...and turn clockwise until it jambs, when tightening. then continue turning clockwise until know aligns with the body, and press down to park.
This is a really great tool.
Oct 10, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
My original blade broke so i bought a new blade from wickes 10tpi now when i use it i saw on the line i have marked but on the other side of the 2x2 it is about quarter to hallf inch out how can i make...
There are good blades and there are cheap blades. Good blades are straighter but less tolerant of poor technique and so tend to break, cheap blades can and do bend far more. You can keep the blade straighter by not forcing the blade through the work and allowing it to cut at it's own rate and by experimenting with the speed settings on the jigsaw. It also helps if you pick the correct blade for the job: 10tpi is a bit too coarse for ripping a timber batten along the grain but fine for rough cutting chipboard. Also, it's difficult to keep the foot of the jigsaw absolutely level on 2x2 which adds to your problems.
Aug 15, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Dewalt DC330K XRP 18v cordless Jig Saw Kit with All - Metal Keyless Blade Change Logo
632 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
