Question about Keurig B60 Coffee Maker
Only a few drops of coffee come out
I've tried cleaning the underside of the water filter with a toothpick, but was unsuccessful.
  • 10,865 Answers
Hi. that filter must be replaced regularly. you can order replacements here http://www.totalvac.com/5072.html
J.
Posted on Aug 01, 2010
I have a Keurig b145 given to me I purchased some new kcups They taste funny. I am wondering if there a filter that needs changing or what in the b145? It has not prompted me to descale it.
try using only distilled water, tap water has minerals in it and can cause buildup and harbor bacteria YUMMY
give it a good cleaning first.
I'm not a big coffee drinker but when (don't try this as all other coffee will taste like GAK )
I make it, I use a french press and Fiji water and 100 Hawaiian Coffee Kauai Coffee Company Buy Coffee Online
Brew Perfect French Press Coffee with this Recipe Crema co
How To Make French Press Coffee
Jay the pool pump motor repair guy longwood Florida 32750
Nov 21, 2017 | Keurig Coffee Makers & Espresso Machines
Water won't flow thru to filter or pot. Don't know the exact model but it is a 12 cup self cleaning.
Self-cleaning is wishful thinking. Every three months or so, run a pint of vinegar through it, as if making coffee (no coffee!) then flush with two tanks of water.
Mar 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
When we go to brew a pot of coffee, part of the time the filter housing will over flow water and grounds
Most likely you have a clog in the filter container. Use a toothpick to clean the small spout at the bottom. Then hot soapy water. Hopes this helps.
Aug 17, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Before this 5 cups coffee maker and do coffee very fast, now it takes toolong to finish, what's wrong? i have the inner filter and keep everything clean and still the same, does it have a heating element...
Try running a few cycles of fresh water mixed with a ``descaling`` solution sold at most grocery big box stores. Run the machine WITHOUT coffee.. Then run a few more pots of fresh water (no descaling solution). ,to clean out any residue. Are you using any type of bottled water when making coffee?? If you are, I would just use tap water or ``brita filtered`` water.
Good luck and happy brewing...
Feb 25, 2011 | GE 106591 Coffee Maker
My keurig saidbto descale, which I did and now hardly any coffee comes out. When I run plain water through withoout the coffee, it comes out fine, but as soon as I put the coffee in, it dribbles out and...
Hi, I think I can help you fix this problem. First off, check the needles that puncture the cups and get them cleaned off with a paperclip or a toothpick. Try to clean them with a small brush or a even a toothbrush with a little vinegar. Clean the top and bottom and be careful because they're sharp. Then, run a full resevoir of white vinegar through your machine. Then, let it sit with "ADD WATER" for a few hours. Lastly, rinse with clear water, a full resevoir so you get rid of the vinegar smell and taste.
Sep 29, 2010 | Keurig B60 Coffee Maker
Espresso machine will not make Espresso.
Try this remove the portafilter and press the brew button, if water comes out of head, machine is fine but the grind or the tamping(packing pressue) used on the coffee is not right. If you are grinding the coffee just before using it, try a coarser setting. If you pre grind at the store then try tamping the coffee lighter.
May 29, 2009 | DeLonghi BAR 14 Espresso Machine
Keurig B60 Coffee Maker Logo
336 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
