Question about MSI K8M NEO-V Motherboard
SWITHCHING MOTHERBOARDS 1. NOT SURE OF WHICH MOTHERBOARD THIS IS,HOW DO I CHECK. ALL I HAVE IS THE BOARD. 2.IS THERE A STEP BY STEP TO PLUGGING EACH COMPONENT IN.
  • 3,083 Answers
Your best bet is to download the manual, and here's the site:
http://www.iusermanual.com/motherboard/msi-k8m-neo-v-motherboard-manual.htm
There are many articles that have information on hooking up a motherboard, just google them until you find a similar board, or one that you can recognize the different functions on. Board are like cars, they all have similar components and wiring, just in different places. I would start with the manual, however, since it often has this information embedded in it.
If you still can't figure it out, I would take it into a computer shop- they're usually glad to help, if they aren't busy, and they usually can find the answers.
Hope this helps...
Posted on Aug 01, 2010
    President:
  • 2,571 Answers
There will be writing on the motherboard in several places, look very carefully and then google
Everything should just plug in without a problem, each device (ide cable/sata cable/CPU/graphics card) uses different shaped plugs and sockets, they can only usually plug in there own sockets.
Unless you are going to a newer technology ( IDE to SATA or AGP to PCI-E graphics)
If it is the same CPU socket type your only small problem may be connecting the front panel wires (led/hdd/reset/usb/audio)
My board is coming on and all system running but no display on the screen
Hello there,
Step 1: Check all connections from the display to the PC
Step 2: Make sure the button for the Display if pushed to the on
Step 3: if you have another display you can use for testing try it
starter Steps there are more let me know if they fail and we keep going thank you and don't forget to Rate
Jan 26, 2011 | AOpen s661FXm-7US (918EM10S6G) Motherboard
How"ll chack motherbord is working good or not?
I can understand that you want to check the functioning of your PC's motherboard. It is not possible for me to write a step-by-step for this purpose. So, I am sendin you a few links to pages with step-by-step for testing your motherboard. Please use the links below. They are 100% OK and reliable:
  1. Link 1.
  2. Link 2.
I think, the above links have sufficient information to help you out. Still, you need any assistance, just post a comment on this answer. I am following up to help you out.
Have a nice day.
Regards.
Dec 13, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My dell inspiron 1300/B130 will not load windows from the hard drive or from windows disks.thru the cd/drive Could there be a problem with the motherboard? I can load win 3.1 from my external A drive but...
Step 1 Check BIOS setting to make sure the CD is recognized by machine and is part of the Boot Order sequence. Preferably, the CD should be first in the boot order.
Step 2 Check CD cable connections to make sure they are tightly fitted into their sockets. Also make sure CD is plugged in and CD is getting power.
Step 3. Swap out cable ribbon. Sometimes these go bad. Hope this helps.
Apr 02, 2010 | Dell (E210882) Motherboard
HOW TO INSTALL MOTHER BOARD
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
  • TIPS AND WARNINGS
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    I just bought my 875WP1-E and hooked the monitor up to the onboard video port and when I power up the computer the monitor just says "no signal." What's up?
    This is due to your system is not switched ON or not properly configured. Follow the below steps will resolve your problem.
    1st Step: Have you hear any beep sounds? If yes insert the memory modules properly.
    2nd Step: check whether the keyboard lights are flashing while switch on the system. if no, check the SMPS or SMPS connections.
    Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    Thank you for using Fixya.
    Feb 20, 2010 | Intel Server Board S875WP1-E Motherboard
    Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
    1. Could be as simple as not having the Power Switch on the right jumper...double check.
    2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
    3. Make sure PS is securly connected to the MB.
    4. Check Jumper on the Board to make sure the Test Jumpers are not set
    5. Memory is seated correctly... if you pull them out the board will start and beep...
    Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
    661fx-m7 no display ,, no boot ,, led indicator lights on
    did you instal the driver for it? if not download from here http://www.nodevice.com/driver/company/Elitegroup/Motherboard/page11.html instal it and check if is working.                              if you have instal the driver then if everything on the board is working fine if some piece is malfunction then it must be changed.
    Dec 14, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
    Power on fans running no video
    Video problem...
    1. Check you VGA connector. Its plug as well or not.
    2. Check the Memory. and try to clean the connector.
    3. Check the cmos batteray. Or reset it.
    before the next step, try 3 step above.
    - Try to change your Memory (RAM) with another one. May be the Memory RAM can't load up the start up.
    May 04, 2009 | Iwill P4ES Motherboard
    My moneter can't disply any thing. There is no problem in moniter I checked it. it's a problem of my motherbord .
    Step 1 -check & make sure your vga cable is properly secured on te compuuter & the monitor
    Step 2- if you have a graphics card in your computer , make sure its properly seated in the slot of the motherboard
    Mar 23, 2009 | Compaq (162857-001) Motherboard
    Plugging in a USB port.
    You have an A side and B side, or 1 and 2. Starting from pin 1, usually has an arrow pointing to it, the wires should read as follows: 1= A/1 +5vac 2= B/2 +5vac
    3= A/1 -D 4= B/2 -D
    5= A/1 +D 6= B/2 +D
    7= A/1 ground 8= B/2 ground
    9= no pin 10= no connection
    Aug 28, 2008 | Intel Motherboard
    MSI K8M NEO-V Motherboard Logo
    88 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
