Question about LEGO interactive LEGO Chess for Windows
Lego Chess wont install under windows 7 64-bit version. When installing from CD the message pops up that the program is not compatible with the Windows 64 bit version and that I should contact the supplier for another version. I have tried to copy the disk to C: and then run it in XP service pack 2 compatiblity mode, however this does not work either. Any suggestions for me? Thanks in advance.
3 Suggested Answers
SOURCE: LEGO Chess
Selectsoft has a patch for this. Download at http://support.selectsoft.com/products/L/LNLEGCHESJ.htm
Works for me.
Marc
Posted on Mar 18, 2009
  • 60 Answers
SOURCE: Wont read the Lego Chess disk
This could be down to ur laser in ur cd-drive.. Could be many of things like Disc data corrupted etc etc. Sometimes if this happens i use a cd cleaner disc tht cleans the laser. These are very cheap.. But down to last resourt... Buy another version of the game. But if tht dosnt work then its your cd drive.
Posted on May 09, 2010
Can cyber chess download to windows 10?
Hi , do you mean that the subject program will not install using Windows 10 operating system ?
If so , try running the app's setup program located on the install disk media in compatibility mode for an earlier Windows version such as XP sp3
Compatibility mode enables a late version native Windows to run a program as per a user designated earlier version Windows and so extend support for obsolete apps that may not run using default settings
Navigate to the install disk's file directory using Windows Explorer (not the browser) , click on the folder to open and scroll down to the setup ( application) file . Right click to open the context menu and select properties > compatibility : check : run this program in compatibility mode and select from drop down list XP sp3 (my guess) or latest published supported Windows version for the subject app.
Check under privilege level : run this program as an administrator
click apply > ok then close and double click app's setup file to launch installation
Hopefully will now install and app will subsequently launch and process correctly.
Jan 28, 2016 | Computers & Internet
Me dice que no es compatible con Windows 7 64 bits
Las sistemas operativas vienen en dos tipos: las de 32-bit (x86) y las de 64-bit (x64). Las x64 pueden usar mas RAM, y son mucho mas rapido en hacer algunas cosas, pero la problema es que no pueden usar todas las programas. Parece que usted tiene una sistema operativa de x64; desafortunadamente, este juego no va a funcionar con su computadora sin instalar otro version de Windows.
Mar 01, 2011 | LEGO interactive LEGO Chess for Windows
I have recently purchased a new PC and when trying to lad Combat Chess the following message appears " incompatibility with 64-bit version of windows" can you help?
there should something in cotrol panel instal that if in compatality with ur current system game will install in compatible system or update drive for game
Feb 27, 2011 | Empire Interactive Combat Chess : Xplosiv...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
May 09, 2010 | LEGO interactive LEGO Chess for Windows
When installing Harry Potter LEGO Creator, I'm getting the message: This program requires that you have 60 Mb of memory on your computer. Setup will now Abort...I have much more than 60 Mb...Do...
Pop the CD in and then Exit from the Autorun screen.
Go to explore the CD and find the Installer icon. Right click and go to Properties. In Properties click the Run in Windows 98 box. Right click again and then hit Run as Administrator. This solved it for me.
Mar 05, 2010 | LEGO interactive LEGO Creator Harry Potter...
Running vista ultimate 32bit. installed lego chess. Crashes just before game starts story mode.Can you help ?
System Requirements of lego chess:
Windows 98/2000/ME/XP
Pentium 166Mhz
4x speed CD-ROM drive
16MB RAM
50MB of free hard drive space
SVGA Video Card (capable of 16 bit colour, 640 x 480 resolution and DirectDraw compatible)
DirectSound compatible soundcard
2MB of video memory
MouseThis is not compatable for Vista Ultimate.Anyhow I suggest you to try in compatabilty mode:
  1. Open Windows Explorer.
  2. Location the application executable.
  3. Right click the executable and click the Properties option.
  4. Select the Compatibility tab.
  5. Select the Run This Program in Compatibility Mode option.
  6. From the drop-down list, choose the operating system you ran before upgrading to Vista.
  7. If necessary, select the option to run the program as an administration.
  8. Click OK.
Thanks and regards, Giridhar
Aug 16, 2009 | Computers & Internet
LEGO Chess
Works for me.
Marc
Jan 27, 2009 | LEGO interactive LEGO Chess for Windows
I start LEGO Star Wars but then says lego starwars stop wrking
LEGO Star Wars II for PC requires the following minimum system requirements:
Operating System
Required: Windows 2000, XP, or Vista
Computer
Required: 100% DirectX 9.0c compatible computer
CPU
Required: Intel P3 1.0 GHz or AMD Athlon 1000 MHz
Recommended: Intel P4 2.0 GHz or AMD Athlon XP 2400+
Memory
Required: 256 MB RAM
Recommended: 512 MB RAM
Graphics Card
Required: 64 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Recommended: 128 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Sound Card
Required: 100% DirectX 9.0c compatible Audio Device
CD-ROM
Required: 8X Speed CD-ROM drive
Recommended: 16X Speed CD-ROM or DVD-ROM drive
Input Device
Required: Keyboard and mouse. Gamepad and joystick supported
Recommended: Gamepad
DirectX
Microsoft DirectX 9.0c (April 2006 Edition) is included on this CD. You will be prompted to install DirectX during the installation of this game if this or a more recent version is not already properly installed on your system.
NOTE: DirectX may require the "latest" updates for your operating system. This may also include the latest drivers for your motherboard, sound, and video hardware.
Installation: Installation requires 3.5 GB of free hard drive space. We recommend that you have an additional 500 MB of free space available after installing the game for the Windows swap/page file.
You must have local Administrator rights to properly install LEGO Star Wars II and update Dire
No other programs should be running in the background.
System resources should be at least 85% free.
To check this:
Press CTRL-ALT-DEL once, choose Task Manager, choose the Performance tab, and check CPU Usage.
There should be at least 500 MB of free hard disk space after installation.
If you experience performance issues when running LEGO Star Wars II, we recommend that adjust the following options in the Video Options menu:
Lower the video resolution.
Set Antialias to Off
If this option is set to Antialias from Control Panel, you will need to set your Antialiasing Setting to Application-Controlled in the Windows Display Properties for your specific graphics card.
Disable Bloom Effect.
Please close all other programs before running LEGO Star Wars II. This includes virus-scanning, word processing, and Internet programs. Simply disabling these programs will not always help, as the programs still use resources that are needed to run LEGO Star Wars II. If you experience problems completely closing programs that are running, consult the documentation for those individual programs. This is a common problem when trying to completely disable virus-scanning software.
Jan 18, 2009 | Origin Lego STAR WARS 2 for Windows, Mac
LEGO interactive LEGO Chess for Windows Logo
3,140 people viewed this question
Top LEGO interactive Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a LEGO interactive Video Game Console and Game Expert? Answer questions, earn points and help others
