Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
How to drain carb
I suspect that I have water in the carb of Briggs V-22 engine on Exmark mower. I don't see any drain plug or screw. How do I drain the water from the carb?
    President:
  • 2,468 Answers
If its a vertical shaft as in the shaft points down,its a 6 sided bolt nexr to the shaft/if its a horizontal shaft its right at the base just above where it bolts to the machine usually below the oil fill cap
Posted on Aug 01, 2010
Where is the drain plug on a briggs and stratton 2014 lawn mower
look on the very bottom of engine look for a square plug screwed into engine on the base that will be your drain plug.
Apr 06, 2017 | Briggs Garden
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
I have a Bolens 22"
There will be a small screw near the carb with a spring around it.That is the idle screw.Turn it left to increase the speed.
Thank You for using Fix Ya.
Jun 04, 2011 | Garden
Where is the sparkle plugs in a yark works riding lawn mower the mower won't start
It should be under a rubber boot between the OHV cover and the muffler.
Drain your carb and check for water in the fuel too.
Good luck and be careful!
Jul 24, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Plugs fouling out
It sounds like you may have water collected in the carb bowl. the fuel gets diluted to the point that the engine won't run and yet when you pull the plug it is wet with the diluted fuel. Drop the carb bowl and see if water is in it or if you have a drain plug just drain it. Check the fuel tank to see if there is water in it also and drain and clean if nesecarry. The water comes from condensation.
Apr 26, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Mower wont start
About the only suspect is water in the fuel - even after you drained it. If your Masport has a 'Quantum' style engine with a float type carb, undo the bowl nut and allow the float chamber to drain. Odds on there's water in it. A single drop will block the jet. If it's a 'carb-on-the-tank' engine, chech for water droplets in the bottom of the tank. They wll be obvious if present.
Mar 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Engine turns over strong but will not start.
I'd pull the carb bowl off first and see if it has water or other crud in it. there should be an oil drain on the bottom, sometimes they are an allen socket plug which sits fairly flush
Sep 26, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
237 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
