Question about Nintendo DSi Black Console
Error code 051099 keeps coming up.
We can't seem to access the internet from our ds. we have entered the following numbers: IP address, subnet mask, default gateway #, DNS (both primary and secondary) and the MTU #(althought not certain that 1492 is correct). we turn on the computer, and we wait for it to connect but it never does!! It says "no compatible access point in range".
any help would be greatly appreciated!!!
thanks
Maria
PS does the computer need to be on for the dsi to have access to internet??????
    Genius:
  • 1,234 Answers
Error Code: 051099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
Posted on Aug 26, 2010
Wat does 5200 error code mean? wat is an IP address?
HI there.
Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps: The first thing you'll need to do is find out what IP address range you should be using. To do this: Click the "Start" button in the lower left-hand corner of your computer. Next, you will need to access the command prompt. To do this: Windows XP users click "Run." Windows Vista users click inside the search bar. Type "cmd" into the box and press Enter. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed. The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The DS and PC must have different IP addresses. Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Nintendo DS and for your PC. Click here to go to our Wireless Router Configuration page. Use the drop-down box on the left to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this on your Nintendo DS or Nintendo DS Lite, please click here. Check Nintendo's router info for special notes, if available, for your router. If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below: If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Thank yo for using Fixya!
Jul 07, 2011 | Nintendo DS Console
EOC 2611P. I follwed the instruction to configure the antenna and when it come tthe time when i typed 192.168.1.1, i don't get the log in box for the antenna. I've been trying many time and i am jammed...
In order to log into this device, you must first configure the TCP/IP settings of your PC/Notebook.
1. In the control panel, double click Network Connections and then double click on the connection
of your Network Interface Card (NIC).
2. Select Internet Protocol (TCP/IP) and then click on the Properties button. This will allow you to
3. Select Use the following IP Address radio button and then enter the IP address and subnet mask.
Ensure that the IP address and subnet mask are on the same subnet as the device.
For Example:
PC IP address: 192.168.1.10
PC subnet mask: 255.255.255.0
4. Click on the OK button to close this window, and once again to close LAN properties window.
Login username and password are both admin for this device
All info on this device can be found here http://www.engeniustech.com/resources/EOC2611P%20User%20Manual%20v1.0.pdf
Mar 12, 2011 | EnGenius EOC2611P 80211bg Wireless Access...
My dsixl will not get on the internet
Feb 28, 2011 | Itronix Duo-Touch II Tablet PC
Whentest ninten WI-FIconnneection get errorcode 52001
Error Code: 52001 It appears that your Wii console is unable to obtain an IP address from your wireless network. Our experience has shown that this error message is solved by performing a manual setup on the Wii. Please follow these steps:
  1. Click the "Start" button in the lower left-hand corner of your computer.
  2. Next, you will need to access the command prompt. To do this:
    • Windows XP users click "Run."
    • Windows Vista and Windows 7 users click inside the search bar.
  3. Type "cmd" into the box and press Enter.
  4. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed.
The IP address you are going to assign to the Wii must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The Wii and PC must have different IP addresses.
Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Wii and for your PC.
  1. Click here to go to our Wireless Router Configuration page.
  2. Use the drop-down box on the left to select, if available, your router manufacturer.
  3. Click on your router's model number, if available.
  4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection.
You will now need to manually assign this new IP address to your Wii. For step-by-step instructions on how to do this on your Wii, please click here.
Feb 10, 2011 | Nintendo DS Lite Console
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Sep 28, 2010 | Computers & Internet
Getting Error code : 052000-1
Error Code: 052000 Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps:
    • Windows Vista users click inside the search bar.
Aug 16, 2010 | Nintendo DS Lite Console
Can't connect to wifi error code 052000-1 how do I correct this
Error Code: 052000-1 Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps:
Feb 03, 2010 | Nintendo DSi Black Console
Cannot get past the IP entering details.
Hello.....If your ISP has given you a static IP address to use to connect to the internet, they should also have given you the Subnet Mask, and Gateway IP Address - these are the settings to use.
If you don't have these settings, you will have a dynamic (variable) IP address. If so, try logging in to the router again, go to Basic Settings, and configure 'Internet IP Address' to 'Get Dynamically from ISP'.
Similarly, if your ISP has given you one or two DNS addresses, enter these up - but otherwise set as 'Get automatically from ISP'.
You might need to reboot one or more times for the settings to take effect. Hope this helps, but please come back to Fixya if it doesn't ...
Dec 30, 2008 | NetGear WGT624 Wireless Router
Installing the compaq home internet appliance
does the appliance have a dchp ip address option or auto ip address option. The IP address is used by the wireless network to identify each computer device in your house.
In your wireless router there will be a dhcp server that will lease out ip addresses to devices automatically.
the ip address would be 10.0.0.1 for your router or 192.168.0.1 usually most used ip addresses .
A subnet mask is usually 255.255.255.0 which is also needed.
Go to your desktop computer and go to command prompt . Google your version of windows and command prompt to work out how to do this.
then type in ipconfig
press enter key
note the default gateway address and the desktop's ip address
you may need to enter the default gateway ip address into the fridge also.
if the desktop was 10.0.0.2 subnet mask 255.255.255.0
then make the fridge if manually have to set it
10.0.0.254 subnet mask 255.255.255.0
or 192.168.0.254 subnet mask 255.255.255.0 if it is 192.168.0.2
the first three numbers are called the network address eg 192.168.0
10.0.0
the last number 1 - 254 are individual address part
192.168.0.1 {router uses this 1 usually } to 192.168.0.254
Jan 16, 2018 | Compaq iPAQ Home Internet Appliance IA-1...
Nintendo Wi-fi Connector Problem
nintendo ds should work with most routers it's just the set thats a problem, once the wifi game is in go to wifi connection one settings,then where it says auto obtain ip address click no, then edit,then use an ip address that is the next digit up from your pc or your router eg, if your routers ip address is 192.168.2.1( this is what you would type in your internet browser to get into the router settings), the next digit used by a pc would be 192.168.2.2, so use 192.168.2.3 or above incase you have more than one pc. Next is the subnet mask which should again be as the routers subnet mask which will more than likely be 255.255.255.0., press edit and enter that number Next is the gateway setting, press edit, this is the same number of your routers own ip address as mentioned earlier this is the ip address you type to get into the router eg 192.168.2.1. next is auto obtain DNS, again click no, then on the primary address click edit and again enter your routers own ip address. next is secondary DNS, again click edit and again enter your routers ip address, then click save settings. You should now be able to connect to your router and the wifi connection at nintendo server.
Jun 30, 2007 | AOpen AOR-401M Router
Nintendo DSi Black Console Logo
266 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
