Question about NewAir ACP-1300E Air Conditioner
Continually fills with water and shuts down every hour
  • 4,924 Answers
Check to see if it has a condense evacuation pipe ...or if it already has ..this pipe not to be obstructed or filled with something ...The water inside the AC is caused by the humidity in the air ..that cause the condense to form on the cold parts inside and if it has no evacuation pipe ...it will accumulate inside and shut it down ..
So the issue is the pipe ...be sure it exist ...(it may have beed removed for some reason ..) and if it does not to be obstructed...or to be in a position that will allow the water to drain ..Aniway the presence of the ewater is normal ..but not in such quantity and it should be evacuated by that pipe as soon as it is formed by condensing ...The pipe should be in the lower side....in fact in the lowest ..so that it can drain ...if for some reason (cause the water was draining and make a mess) you obstructed ..or lift it up ...release it ..amd put some kinda tank there or something to drain in ...
Posted on Aug 01, 2010
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
Why won't it drain through the hose?
continuous drain option, So was there a plug in the end of pipe, did you remove it, does your pipe run down over, has to. Not a lot between bottom of unit and floor, But pipe has to go down over, if up and down, will not drain. down all the way
Aug 13, 2014 | Haier DE45EK DE45EK-L 45 Pints...
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Water continues to fill the tub. Will not shut
Hello.......It is possible that the little tube running from the pressure switch to the tub is holed.......if so the water will continue to fill and the appliance will not start...Follow the tube down to the tub..or expansion chamber examining it for damage .you can repair this by splicing or replacing the tube..
regards Sir Galahad
Aug 27, 2009 | Washing Machines
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
NewAir ACP-1300E Air Conditioner Logo
Top NewAir Heating & Cooling Experts
gbob59
Tom Chichester
Bill Boyd
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
