Cars & Trucks Logo
Posted on Aug 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiper motor starting making a noise (almost a grinding noise) next day when I turn on wipers they moved up about 2" and then totally stopped in place. Can't get them to budge. I also thought i noticed the wipers moving a bit slower then normal before this problem.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 289 Answers
  • Posted on Aug 02, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
289
Questions
Helped
73829
Points
783
There is a motor above the firewall in the engine compartment.(Not easy to get at). To that motor there is a gear that attaches the motor to the wiper arms. Tighten that connection. You may want to try to turn the wipers on then off. Thiss will put the blades in what it thinks is the rest position. Other wise they may be out of wack. So with the wipers off loosen the drive gear force the wipers down all the way and then tighten.
Good luck.
ash
My windshield wipers moter is running but wipers not moving I got a 2002 ponniac Bonneville
If upon turning the switch, you hear either a buzzing or a noise coming from the wiper area but no movement of the windshield wipers, then it becomes likely that there is a mechanical problem. In front wiper systems, there are two moving parts, the wiper motor and the wiper transmission. In rear wiper systems with a single wiper, there’s a single moving part, the wiper motor.
If you hear a buzz, it could be a motor straining to move a jammed wiper transmission or a locked motor gear. If you hear a grind coming from the wiper area, it could be a stripped gear in either the motor, the transmission or where the wiper arm splines to the wiper motor in the rear. Don’t let the term transmission fill you with dread; it’s simply a term for a multi-lever set of arms and hinges that turn the circular motion of the wiper motor into the side to side motion of the wiper arms. It is also possible that the spline on the post of the front wiper arms is stripped.
Generally speaking, you can reach the motor and transmission by removing the wiper arms, all the screws that hold the cowl beneath the wiper arms and the weather stripping. Once exposed, you should be able to remove the motor from the transmission and check to see if the transmission is binding or if the motor is the culprit. Simply, replace the culprit, and reassemble.
If the problem is with the rear wiper system, getting to the wiper motor can be more difficult with far more trim to remove than with a front system. You may elect to consult your mechanic for help.
2answers
After a brief snow and freeze, my wipers stopped working. I left the wiper switch on when I turned off the car. Next day, after scraping the ice and snow, I started the car, the wipers wanted to mov
The wipers lost their index... Turn the car on, turn the wipers on, shut the car off when the wipers reach their full down position. Turn the wipers off, the. Turn the car back on. This should relearn the wiper index.
2010 Lexus ES 350 WINDSHIELD has suddenly stopped moving, the motor make noise , the windshield not moving , what could be the cause and solution
It is either time to replace the wiper motor or the arm has disengaged from the transmission. does the motor make any sounds when the wiper switch is activated? Also, does one work and not the other? If neither wiper moves or makes the usual noises i would suspect the switch inside the car. hope this helps and good luck.
HELLLPPPP !!!! Audi A4 2003 Wipers don't work because an electrical fault !!! Hello everybody !!!! I have a problem with my wife's car: audi a4 (b6) 2003 1.9 tdi 130 hp, RHD Last week after a...
-You mean There is 12 V at motor terminal when you turn on the switch.
-Okay now disconnect power at motor and hook up voltmeter to motor terminal in Ohm. Any reading...?
-No. motor is bad.
-Yes. The motor is Okay.
-Next check ground terminal from motor to any metal part of the car in Ohm. Any reading?
-No. >>Need to redone ground from motor.
Mai
Wiper blade on my 98 C230 goes a quarter of the way up then stops and makes clicking noise for about 10 seconds. When I move it by hand it will go back into start position. Should I still try the lube...
sounds like the gears inside of the wiper mechanism have gone bad. there is a strip of gears in the shape of a half moon that the wiper motor rides on in order to move the wiper blade back and forth. When those gears strip out the wiper will only move a certain distance and then stop. One way to tell is if you can move the wiper arm by hand. When the gears are good the wiper arm should not move at all by hand.
3helpful
3answers
Pontiac g6 2006 wipers stopped movement while driving. what could this be from? I already checked fuses. i hear the motor running making noise.
either linkage broke/ jammed or motor is stuck -makin noise but not movin open hood and with wiper on feel motor- its on firewall-for movement if moving turn off motor now try to move wipers if move freely than they are broken off or have disconnected from the motor need to remove the cowl to access the wipers linkages
Wipers wont work
1.  Turn on your wipers and pop your hood.   2.  If you hear you wiper motor, then you do not need to check your fuses. 3.  If your wiper arms are moving freely, then your linkage from the wiper arms to the motor is disconnected and possibly broken.   4.  If the problem is electrical, do the following:      1.  Check the fuse, and check for power at the fuse.      2.  Check the wiper motor for ground. For a complete circuit, you need power going in and ground               coming out.  Check electrical connections for corrosion or poor connections.       3.  Get a wiring schematic and trace power to the wiper motor starting at the fuse box in the                       following order:           Fuse box           wiper switch           wiper motor      4.  In the rarest of cases a wiper motor or wiper switch is at fault.  I do not recommend replacing                 anything unless you have proof that the part is faulty. (ie. power going into the switch but nothing           coming out.)
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
