There are a lot of vertical multicoloured lines and 2 grey horizontal lines across my LCD screen and i wondered how i could fix it? Or do I need to have it replaced completely?
  • 734 Answers
HI there,
Before you do anything else, using your own (or a friend's) external monitor, connect your laptop to the monitor and see if the display looks the same as your laptop dos. Sometimes, once the cable is attached, you have to look up along the top of the keyboard at the F keys and see if one looks like a symbol for a monitor. If it does, you need to hold down th fn key and then press that F key to transfer the display signal.
If the external monitor shows a regular display of your laptop's screen, then you know that the problem is either the Screen Inverter, or LCD. As a laptop repair specialist, I always replace both because the inverter is right below the LCD panel behind the "frame" that goes around your LCD (screen).
If the external monitor looks exactly the same as your laptop screen with the same problem, then you know that the Video chip or card on the motherboard is about to fail and needs to be replaced. You then have the choice of replacing the entire motherboard or sending the laptop to a company that specializes in motherboard repair. Many can be found on eBay (I use them myself if the Video chip is soldered to the motherboard).
If the video chip is not soldered, it alone can be replaced. Some of them can be very expensive, all depending on your laptop model.
By going by the above diagnostic method and doing a little research, you'll be well enough informed to make the right decision for your own circumstances. I'll cast my vote that it's only the screen. :)
Good Luck
Posted on Aug 01, 2010
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Why is my screen green?
you may change the connection cable
Aug 18, 2015 | ASUS VW246H 24 Widescreen LCD Monitor,...
Black lines running across the sony ericssons w580i screen
if only vertical or horizontal line across you LCD display
your LCD need to be replaced.
your LCD cannot be fix.
Mar 07, 2011 | Sony Ericsson W850i Cellular Phone
I have a 2 in. horizontal grey line to the right of my acer lapt
anytime you have lines on your lcd screen on a laptop, its the lcd that needs to be replaced, those cells in those lcds are so sensitive that they can go bad easily. Get the lcd replaced that will definitely fix the problem.
Jul 06, 2009 | Compaq Presario M2000 Notebook
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Vertical lines on my laptop screen
white vertical line on my screen of my laptop..how can i fix t
Oct 26, 2007 | Compaq Presario M2000 Notebook
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Blank screen except for a vertical grey line through the middle
The horizontal sweep signal to the yoke is bad. Since other problems exist, the problem may be in the IHVT HI voltage transformer area. Check for bad solder around the IHVT pins and yoke plug. I hope this helps. Lee http://www.CrazyComputers.com
Jun 22, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Computers & Internet Logo
108 people viewed this question
Alun Cox
David Payne
David Payne
