Question about Sony Cyber-shot DSC-H7 Digital Camera
Sony dsc-h7 E:61:00 error - Sony Cyber-shot DSC-H7 Digital Camera
  • 38 Answers
Below is detail of Error
sony dsc-h7 E:61:00 error - f8b5q9ipcdnk0yaaaaasuvork5cyii=
Procedure how to replace Lense
i2cie0ly39aaaaabjru5erkjggg==
Now you can get every thing related to fault.
Kind regards.
Posted on Oct 18, 2017
Clog2020
  • 81 Answers
SOURCE: Error code on screen E:61:00
Try resetting your camera to factory defaults:
  • Turn off the camera.
  • Ensure the camera is not connected to an AC power adapter.
  • Remove the battery from the camera for 15 seconds.
  • Reinsert the battery.
  • Turn on the camera.
  • Posted on Apr 18, 2008
    swami nathan
    • 208 Answers
    SOURCE: Sony Cyber-shot Error Code E:61:00
    you may have these symptoms,
    Symptoms :
    1. After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
    2. Camera would extend the lens but not be able to focus on anything past 8 inches or so.
    3. Zoom in and zoom out would not work.
    4. Playback mode and the Setup mode was not affected.
    To fix this problem,
    Do these...
    A) Put the camera about a half inch from a hard surface.
    B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
    If that doesnt fix it, try this:
    A) Turn it on and let the lense go out fully
    B) See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
    Now turn it off/on again, and it should be fixed!
    If not, try these steps a few more times. If still nothing, then I suggest you to call Sony, but this DID work for 90%, so hopefully it''ll work for you :)
    Thanx for using fixya,
    Cheers.
    Posted on Sep 27, 2008
    SOURCE: Error 61:00
    I found this on another website. After trying the bang and blow method....I found that it really does work!!!! I thought I was going to have to buy a new camera. I am SO thankful to have found this. I hope they don't mind me reposting it on this site.
    Added by Phillip Ewing on 04/Jan/05 at 04:44:53
    We had the same problem, and we fixed it! First, identify that it''s the AF motor drive by A) Turning it on and putting your ears against the camera, then hearing a humming noise for about 5 seconds. B) The error comes up flashing on the screen: "E:61:00". Okay, so you''ve identified your problem! Next you wanna fix it, right? ;) A) Put the camera about a half inch from a hard surface. B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time. If that doesnt fix it, try this: A) Turn it on and let the lense go out fully B) See where the lense comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!) Now turn it off/on again, and it should be fixed! If not, try these steps a few more times. If still nothing, then I suggest phoning Sony, but this DID work for us, so hopefully it''ll work for you :)
    Posted on Mar 11, 2009
    aneesh ch
    • 73 Answers
    SOURCE: sony DSC T70 fault code E:61:00 any idea how to
    e 61 means lens problem chaing lens unit
    Posted on Jul 11, 2009
    SOURCE: My sony dsc-t70 is flashing E:61:00 and will not
    Mine was an E61:10....I think. I read on a thread that it was a lens barrel issue that could be fixed with a smack, so I closed the lens cover, turned the camera on and gave it a whack with the bottom of my wife's vintage wine glass....I picked the camera off the carpet and turned it on to find that the error message was no longer active and the wine glass was still in one piece. I rule!
    Posted on Apr 03, 2010
    How to recover error E:62:10 on Sony DSC T30?
    Just did what "dcamille84" said to my Sony DSC-T30 and the error message went away - CRAZY! Unfortunately, I already bought a replacement camera though (was only 100 bucks new).
    Dec 13, 2010 | Sony DSC-T30 Digital Camera
    Dsc-f717
    The Sony DSC-F717 will only take upto a 256MB Memory Stick - larger size Memory Sticks will give the C: 13:01 error. Use a correct memory stick and your camera should be fine. Regards, Andrew
    May 10, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
    How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
    how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
    Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
    ERROR CODE 91.01
    this is my same problem in my Sony Cyber-shot DSC-W130., pls e mail me if someone answer your problem., this is my e add -- helterbrand_16@yahoo.com ur.goingdown@ymail.com
    thanks.pls..
    Dec 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
    Sony cyber-shot dsc-w50 problem
    Hi!
    It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at toms.safranovs@gmail.com or contact your local Sony service center.
    I work in a Sony service center.
    Tom
    Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
    Error
    is there an error # behind it?
    Jul 21, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
    E:62:10
    Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
    Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
    Sony Cyber-shot  DSC-H7 Digital Camera Logo
    159 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    JonSnell Electronic
    JonSnell Electronic
    Are you a Sony Camera Expert? Answer questions, earn points and help others
