Question about HP Photosmart 8150 InkJet Printer
HP Photosmart 8150 Ink Jet error message
Had a paper jam, cleared that and something popped out. Black plastic docking thing that has a UPC label on the bottom with P/N 5064-4593
and AF Made in Hungary. I think it came out of the left side of the printer when you open it up. Window error message says: Cartridge Service Station is stuck. Press OK. I pressed OK and the ink cartridges move across to the left side and it makes a funny grinding sound and then they move back into place. Help...I need to print my grandsons birthday card.
  • maconklin Apr 25, 2008
    I am having a problem with determining which ink cartridge to use for my Photosmart 8150. I purchased the HP 96 black ink cartridge but it will not fit. It is too big to go into the slot. Am I supposed to always use the tricolor cartridge? I would like to use a black cartridge.
  • 7 Answers
SOURCE: HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Posted on Dec 18, 2007
wborg1231
  • 36 Answers
SOURCE: error message on photosmart 8150
Well, what you want to do is you will see a wire coming from your cartridge, pull that wire (not hard) just so that way you can move the cartridge and you should be able to fix that problem.
Posted on Apr 25, 2008
SOURCE: hp officejet j5780 Constant paper jam
clean feed rollers
Posted on May 12, 2009
solasknows
  • 199 Answers
SOURCE: Get error message
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Posted on Jun 26, 2009
  • 53 Answers
SOURCE: We have an HP C6180. Carraige jam with grinding noise
perform the steps in the webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&lc=en&dlc=en&product=1153494
Posted on Oct 03, 2009
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
There is a print cartridge crudle is stuck...clear jam and press ok saying on the screen of my printer what should i do?i cleared the paper jam but it still says the same thing
Remove your cartridges, pull the power out see if the cradle moves freely around by hand. Check make sure that theres no paper that stayed behind. Did you rmove the paper by force? Maybe you dmaged the paper sensor.
Dec 08, 2008 | HP Photosmart 8150 InkJet Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Error message on photosmart 8150
Apr 25, 2008 | HP Photosmart 8150 InkJet Printer
Paper jam
is paper crinkled or is printer just giving a jam error/
Jan 15, 2008 | HP Photosmart 8750 InkJet Printer
HP D155xi - Error Message: Clear Paper Jam (when there is none)
Have an HP office jet d155xl printer and every time I put it on, it takes sometime to warm up then the "scanner failure" pops out on LCD with instructions to put printer off and on again. Same thing happens all over again.
Oct 18, 2007 | HP OfficeJet D155xi All-In-One InkJet...
HP Photosmart 8150 InkJet Printer Logo
337 people viewed this question
Ben Johnson
