Question about Philips 170S5FS 17" LCD Monitor
Screen size reduced horizantally at the ends,even monitor controls are adjusted maximum.
    Scholar:
  • 104 Answers
You will have auto adjust button in ur monitor! if you have that, try pressing that button. It will set the the monitor resolution to the optimum level.
Posted on Aug 01, 2010
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
My H-size and V-size are at maximum 100 but the screen but screen is still small for the monitor size...what could I do to fix this??
There are two ways to adjust the picture, the best way is simply to use the buttons on the monitor, if that doesnt work negotiate to the software adjustments by right clicking on the screen and going to properties.
Nov 04, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
I have a 17" CRT monitor.. When I was using the computer, suddenly the monitor screen size reduced like some kind of pincushion effect to the maximum... When I tried the option buttons provided below,...
if you are technical person open the monitor the biggest part named E.H.T. look at its heat sink a double diode attached to heat desoler it check it and replace it even found ok by multimeter
Aug 29, 2010 | Dell Computers & Internet
I want defalt settings of samsung syncmaster 793s 2004 model monitor
The default resulution is 1024 x 768, you can keep the Screen Refresh list at 75 Mhz
If you have been at "Out of Range" then you need to reboot and press F8 before windows load up, then choose VGA Mode. When windows finished loading you can fix the resolution again as you like. Hope this fix your problem
Best Regard!
Dec 03, 2008 | Samsung 793S 17" CRT Monitor
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
Over-drive vertical height on monitor screen
1. back side of LOT one TIP 122 FET replaced.
2. Near to LOT PF 424J / 1600v change.
Nov 17, 2008 | Computers & Internet
On Screen Display is being shown permanently
Its aproblem of command section.Check its components one by one.you can identify this section (the front panal buttons goes in this section and a ic in big size and pasted horizantally in the circuit).if the components are ok then change command ic with new one.This will solve your problem.
Jul 31, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56V monitor
Jul 27, 2008 | SAMTRON 55V 15" CRT Monitor
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Mar 10, 2008 | LG Studioworks 45 14" CRT Monitor
Philips 170S5FS 17" LCD Monitor Logo
202 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
