Question about Whirlpool RF111PXS Electric Range
I have a Whirlpool oven model number RF111PXSW. The oven does not work but the range top burners still do. How do i fix oven?
fridgetech
  • 473 Answers
SOURCE: oven will not work
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 03, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
dmftrucker
  • 1922 Answers
SOURCE: Where do I find the model number of my GE Profile gas range?
on back of appliance near top behind control panel but should be on outside of rear cover
Posted on Jul 28, 2009
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
My whirlpool range oven is not working. Burners on top are working fine. Digital lights on the oven such as start and setting are off, no power, apparently
Either your electronic oven control is bad, or else your neutral wire to the range is open or disconnected.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 19, 2014 | Whirlpool Kitchen Ranges
I have a Whirlpool Electric Range GY399LXUS. The oven will not turn on. The top burners work, the only button that works on the keypad is the warm button.
I am an Appliance Technician...... and you need a new clock/ECM The part where the clock is & the oven controls... under there is a big circut board that is basicaly the motherboard for your oven. And I'm sorry to inform you that I just used your model number to look up the board and it is NO LONGER AVAILABLE.... that means they just don't make that part for your oven anymore. Whirlpool didn't use that design very long because they didn't sell well, they were expensive to produce, and they had a few too many problems out of em. So BAD NEWS is they don't make the part you need to fix your oven....GOOD NEWS is you get to go shopping for a Range!!! And BUY WHIRLPOOL!!!!!! DO NOT BUY LG,SAMSUNG, GE, FRIGIDAIRE, OR ELECTROLUX!!!!
Aug 05, 2011 | Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Burners not comming on
Remove the grill and slide out the glass top. Take a close look at them burner. If all look ok then it may be the switches.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | Whirlpool RF379 Electric Kitchen Range
My display says E2 -F3- what is the problem (electric range)
E2 and F3 three means that your oven is getting too hot. Replace the oven temp. sensor and it will fix it. If you get me the model number i can get you a part number for the sensor.
Nov 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Whirlpool oven doesn't work model gs563lxss
May 15, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool RF111PXS Electric Range Logo
87 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
