Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
When i try to bake in my kenmore gas oven it gos to self cleaning mode and will not let me use the oven
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
Some how somebody pressed self clean and didn't let it finish. Press self clean again, let it run thru' and then U wil B A O K.
Posted on Aug 02, 2010
I have a Kenmore Electric - while trying to use the self cleaning instuct.,I can't get the oven to auto lock -it goes to bake and keeps beeping, please help
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Mar 05, 2011 | Ovens
I have a Kenmore gas range model # 7907578890. I pushed the clean button to clean the oven, door locked and cleaning started briefly then stopped. Door stayed locked. Now oven won't respond to any buttons...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 18, 2011 | Kenmore Ovens
When I try to bake something it takes most of the time twice as long as it should. Its like the oven says 350 but its only 175
if you have ever used your self clean feature you probably damaged the sensor.I found out the hard way. NEVER use the self clean
Jun 09, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a kenmore self cleaning gas oven. the pilots light, the broil kicks on, but preheat won't start. what can i do?
Ok well heres the deal. I'm assuming that because this is a self cleaning oven then its probably fairly new in which case you probably don't have actual pilot lights on there but "glowbars" which are called ignitors. If this is the case, and you can see your ignitors for the bake and broil both glowing then chances are you have a weak bake ignitor. If the ignitor is not getting hot enough, then it will not send enough current to the gas valve to energize it (allowing it to open and let gas in). If its not glowing at all you can just get a voltage detector (you can buy them at walmart for about 10 bucks) turn the oven on and use your wand to see if the ignitor is getting power. If it is then its going to actually be open or shorted.
Overall deal is that 95/100 times if you have a gas oven with ignitors and its not baking its and bad or weak ignitor. They cost about 60-90 bucks.
If your oven does indeed have a pilot light then you will have a bad thermocouple or possibly obstructed burner tube.
Hope this helps _MJ_
Feb 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore oven locked door light on but not, won't bake
Check your breakers and also your wiring. Try to turn off the breakers for about 10-15 seconds. Your board inside the control panel may be bad since you are getting mixed signals.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
105 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
