Question about Magellan Roadmate 1200 Car GPS Receiver
Error Your device needs to be restarted to increase performance ... have rebooted many times
SOURCE: magellan 4700 your device needs to restarted to
on my magellan GPS I get the message "your device needs to be restarted to increase performance, Please wait while your data is saved
Posted on May 08, 2010
  • 3 Answers
SOURCE: i typ the address that i want to go to and it
Mine started doing the same thing about 2 weeks ago and I just got around to reading if there is a solution but it appears it's a common firmware issue. In the meantime to get around the problem, you can enter the address into your address book and then it works like normal
Posted on Jul 21, 2010
SOURCE: your device needs to be
i have a GPS Magellan 1440 and a error message: "your device needs to be restarted to increase performance", it's happening each time i try to enter a new address. Can you help me please, thank's!
Posted on Dec 21, 2010
mc1bean
  • 3053 Answers
SOURCE: i put my gps in my carfor 2 days & third day
This is normal, sense they are are all controlled via safelight and computer , they are constantly updating. I recommend once a month you manually reboot gps, to keep bugs out as well as accurate speed and performance. To manually reboot, turn off like normal, but when turning on hold on button down and keep down through opening process for about 15 seconds then let go of on button. Then is cleaned up and rebooted. Thanks mike from fixya
Posted on Jun 09, 2011
mc1bean
  • 3053 Answers
SOURCE: message on gps says, your
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike.
Please don't to vote or rate this , if I helped you. Thanks Mikemc1bean_8.jpg
Posted on Jun 16, 2011
Need to reset the ingenico isc250
Holding the Clear button and the "-" button will reboot the device.
Apr 16, 2013 | Ingenico iSC250 Payment Terminal
Magellan gps , how to restart i I receive the message your device needs to be restarted to increase performance. please wait while your data is saved. isthere something i can do to alleviate this...
To restart the device, just press on hold the power button or slide the switch to on position and hold until the unit turns off. You may also want to update your untits firmware. Please visit http://support.magellangps.com/support/index.php?_m=downloads&_a=view to see if there is an update available for your unit.
Sep 26, 2011 | GPS
Doesnt let me get directions
Let's try something, no guarantee, but let's try and manually reboot it. I do this once a month to clean up memory clutter and it's like flushing system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 17, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Message on gps says, your device needs to be restarted to increase performance...please wait while your data is saved
Jun 16, 2011 | Magellan 2055 GPS Receiver
I put my gps in my carfor 2 days & third day when i started my gps its mention 'your device needs to be restarted to increase performance.please wait while your data is saved.
Jun 09, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Your device needs to be restarted to increase performance? Please wait while your data is saved?
Sep 25, 2010 | GPS
System won't boot to operating system. Error 00170019200163
Write down the exact error messages ....... that you receive while the computer is booting Windows.
  1. Click "Start > Run Type "msconfig" in the field and click "OK." Click the BOOT.INI tab.
  2. Check the box next to "/SAFEBOOT." Choose "MINIMAL" to reboot Windows in safe mode. Select "NETWORK" to reboot in safe mode with network support. Choose "DSREPAIR" to reboot in Directory Service restore mode.
  3. Click "Performance and Maintenance" in Control Panel. Select "System." Select the "Hardware" tab. Click "Device Manager." Select the device that you added to your computer most recently. Right click the device and select "Properties." Click the "Troubleshoot" button and select the option that best describes the symptoms your device is experiencing.
  4. Click on all of the plus signs next to the entries in Device Manager to expand all the devices. See if there are any black exclamation marks on a yellow triangle. This indicates a problem with your device. Also see if there are any red X marks near the devices. This indicates that the device is disabled.
  5. Click "Start > Run." Type "msconfig" and select "OK." In the BOOT.INI tab, uncheck the /SAFEBOOT option. Reboot your computer. If the computer starts normally, you're finished. If it doesn't, reboot in safe mode and click "Start > Control Panel > Performance and Maintenance > System Restore. and Select "Restore my computer to an earlier time." Choose a date on the calendar that is at least one day prior to the time that your computer began experiencing boot problems.
  6. Reinstall any software programs or hardware you removed one at a time. Reboot the computer after each installation. Make careful notes of any error messages or boot problems you experience.
All the Best
Aug 21, 2010 | IBM ThinkPad 600E 2645 Notebook
Magellan 4700 your device needs to restarted to increase performance. did this about 25 times, what is wrong
Apr 10, 2010 | Magellan GPS
Magellan Roadmate 1200 Car GPS Receiver Logo
521 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
