Question about Health & Beauty
Commander victory XL4 How do you fit new battery
  • 677 Answers
Replacing a battery on a scooter can be a simple task, providing that you have an understanding of basic electrical skills. Unfortunately, most scooters conceal their batteries under their plastic skins. While the battery's whereabouts are listed in their owner's manuals, most used scooters are sold without the manual. This leaves the new owner to play hide and seek in order to find the battery. Luckily, finding and replacing the battery is very easy.
Things You'll Need:
  • Phillips screwdriver
  • Battery
Locate the scooter's battery compartment. On most scooters, the battery will be housed in a tray mounted under the seat or in a compartment beneath the floor board. If the battery is housed under the floorboard, remove the battery panel with a Phillips screwdriver.
Disconnect the wire leads that connect the scooter's wiring to the battery's terminals. Use a Phillips screwdriver to loosen the screws, starting with the negative (-) terminal first followed by the positive (+) terminal. Pull the old battery out of the compartment or tray. Take note of the orientation of the original battery.
Insert the new battery into the tray or compartment, orienting it in the same direction as the original battery. Use a Phillips screwdriver to connect the wiring leads to the battery's terminals, starting with the positive (+) lead followed by the negative (-) lead.
Replace the battery cover panel or close the seat.
Tips & Warnings
  • Charge the new battery completely before installing it into your scooter. A partially charged battery will not provide the necessary voltage, preventing your scooter from operating properly
  • To prevent the risk of a serious electrical shock or short-circuit, do not allow the negative (-) wire lead to contact the frame.
  • Do not connect the negative (-) lead to the positive (+) terminal, or vice versa, to prevent damage to the scooter's electrical system.
Scooter Battery Maintenance
Are you frustrated every summer by a scooter that won't start at least once a week? You probably aren't maintaining your battery properly, and you might be causing damage to your scooter's electrical system if you're jump starting from an automobile.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
    Buying a battery
  1. Consult your scootetr's owner's manual to make sure you have an appropriate model battery for your vehicle. In fact, it's a good idea to take the manual with you while shopping for all your scooter equipment.
    Batteries for motorcycles and scooters are notorious for wearing out or breaking down ahead of schedule. It's a good idea to get a battery with at least a 6-month warranty.
  2. Removing the Battery
  3. If you need to replace the battery or take it out of your scooter to recharge it, start by unscrewing the negative wire first, followed by the positive. When you're reinstalling or replacing the battery, this process should go in reverse order--positive, then negative.
  4. Storage
  5. If you need to store your scooter for an extended period such as winter, disconnect the battery from your vehicle to avoid the slow and steady drain from things like clocks. Make sure that the battery has a full charge before you start it in the spring.
  6. Maintenance Do's and Don'ts
  7. Don't charge your battery up with your scooter, if it can be avoided, and don't jump start your battery with a car. Instead, use a battery charger to keep your battery charged, and be sure that it's set on the proper voltage.
    Replace the spark plugcommander victory XL4 How do you fit new battery - mag-glass_10x10.gif as often as possible; monthly is ideal, but probably not necessary unless you use your scooter to commute.
    Check your fuses often and make sure that your fuseholder doesn't have corrosion. If it does, replace it.
Good luck.
Posted on Aug 01, 2010
Pride victory xl4 does not work when key is on i have taken it out put it in nothing happens
Some good advice here. If nothing works it could be that the hidden main fuse has blown, (one cause might be shorting the XLR three pin charger socket by getting it wet or a faulty charger connection. The hidden high amp fuses that Pride doesn't tell you about are under the main floor mat and trapdoor. First disconnect the batteries then remove the large central floor mat. (if you have trouble refitting it later glue it back using clear silicone bath sealent nscrew and remove the hatch lid and very carefully locate the fuse box containing two high amp standard car fuses, check and if nessary replace the blown one with the same amperage rating
Jun 06, 2017 | Pride Health & Beauty
Why is my shop rider deluxe not working proper with new battery's
Is the high low speed switch turned to high. If it is and its still slow it would indicate a throttle pot fault
Jul 06, 2014 | Shoprider Sprinter XL4 Deluxe
I have no swivel levers on my sprinter xl4
hi, some of the older style seats do not have them fitted....so the seat cannot be moved forward or backwards, only around ...
Regards
Rob
www.gewizrepairs.co.uk
Apr 29, 2014 | Health & Beauty
Just bought a 2011 Victory Cross Roads. I also bought a Roadlok wheel lock. Put is on and strtched the brake line tight. Found out I needed a 2 inch longer line. Bought a universal line, but the banjo...
Hi, Harley_mouse the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2010 Cross Bikes pdf service manual
Motorcycle Service Parts Part Finder Victory Motorcycles Store
Victory 2011 Cross Roads Manual owners manual
2011 Victory Cross Roads Core Custom specs
Victory Motorcycles wiki
Aug 31, 2017 | 2011 Victory Cross Roads
Celebrity XL4, when going up hill, power cuts out. turn key off and back on, scooter will go again for a couple of feet.
Sounds like Overload Cutout ??? Use a Higher Rating Cutout, as going up hill is very hard on Scooters and it also depends on your weight.
Gerry
Aug 11, 2010 | Pride New Mobility Victory XL 4 Wheel...
Scooter will just go in reverse and stay in after
Hello,you need to get someone to refit your forward reverse lever.im disabled myaself.please give me a thumbs rating 1 to 4.i do this as i care not for profit Colin.
Jul 31, 2010 | Pride New Mobility Victory XL 4 Wheel...
Shoperrider no drive just a click
Hi. Sounds to me as if you have a sticky carbon brush in the motor. Each brushe is held in the motor by small black plastic or bakealite cap that screw in the outside or the brush holders. If these caps are not tight enough then the brush or the spring will arc from the side of the brush holder. This causes the brush to become jamed, and does not contact with the commutator on the armature.
You need to remove the brushes, check that they slide freely in the brush holders, fit new springs if neccessary, and reassemble. If the brushes are too tight, the file very carefully on the sides to allow them to move freely. Do not tighten the black plastic caps too hard or they will break, but they have to be snug. Be carefull.
Good luck. Neil.
May 28, 2010 | Shoprider Sprinter XL4
How to remove seat and get access to battery for Victory Vegas 2003 Motorcycle?
Find a key hole to fit your ignition key around LH or near end of seat b4 tail light, insert key and twist 1/4 turn which ever way it release a seat latch..
Apr 12, 2010 | 2008 Victory Vegas Jackpot
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
