Question about Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
I have a leak at one of the fittings on my Culligan RO system. The leak is at the filter unit, on one of the lines connecting to the holding tank. Is it possible that too much air pressure in the holding tank could cause this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Posted on May 19, 2011
My Culligan AC-30 RO system, original owner installed in 2000, started leaking to the drain last night.
I believe as vague memory recalls their is a back wash or bypass of the ro filter system. Is the leak to the drain from a tube? or from the unit? IF you have a pump, the pressures are high entering the ro filter. If no pump they are no more than the city water. But given the age, plastic parts may be approaching their end of life. I Don't know what that is, but you might google this model and see if anyone is having these kind of problems.
Mar 28, 2015 | Culligan Tools & Hardware - Others
Culligan AC-30 Howling Noise
yes you answered your questions there. i researched info and more than likely it is the valve
http://watersoftenernews.blogspot.com/2014/02/culligan-water-softener-noise.html
Oct 13, 2014 | Culligan RO Compatible AC30 Compatible...
I have a leak with my culligan RO system. The leak is on the RO line, at the junction with the line coming from the main tap line. there is a plastic tee fitting there. My first assumption is that there is...
plastic line and fitting are a snap in item
push the line in and at the same time press in the ring at the end of the fitting
that releases the clamping action of the line
make sure that the water is turned off and the pressure in the line is released
Jul 08, 2017 | Culligan Under Sink Water Filter
Leaks on the top of black box of culligan water softner under sink system
Is this a reverse osmosis drinking water system? If it is it is an H8 RO. If so shut the water off that feeds the RO. The leak is probably coming from one of the fittings, they can be cut by the compression fittings and leak.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
My undersink RO system leaks at all four tube connections on the manifold. I inspected the fittings and the o rings are fine. I inspected the tubes and I cut off the ends of each piece to make sure that...
The quick connect fittings need to be fully seated or when pressure is applied they will leak. If the feed is pressure is high to the RO I have seen this occur also. JG John Guest makes a small locking clip that goes on these fittings to hold them tight. Here is a link to JG which shows this application.
http://www.johnguest.com/Home/applications/beverages-and-drinks-dispense/Inch-Size-Accessories/LOCKING-CLIP.aspx
RJ
Sep 05, 2010 | Culligan Under Sink Water Filter
Leak from connection of Culligan under sink water purifier. Who sells replacement parts?
If the leak is coming from the "quick connect" fitting then either the tube is not pushed in all the way or it is loose. There are small "snap rings" that fit between the fitting and housing to hold them tight from John Guest. If the leaking line has a compression fitting they are available at any hardware
This on-line supplier has Culligan filters and John Guest fittings
http://www.freshwatersystems.com/
RJ
Apr 14, 2010 | Culligan Under Sink Water Filter
Our R-04 under sink water holding tank, for our culligan water filtration system got drained, and the pressure is now gone and it won't fill up on it's own. We had a leak, fixed it, but now need help...
The RO tank will still fill up even without any pressure it just won't push any water out. If the RO tank lost pressure and it is a sealed tank, it should be replaced. The bladder is bad.
A 3 gallon tank should have 7psi pre-charge pressure, 10 gallon 10psi. There must not be any water in tank to set the pre-charge pressure.
If the RO tank is not filling up then there is another problem.
RJ
Jan 26, 2010 | Culligan Under Sink Water Filter
My Culligan RO faucet has an ''air gap'' leak. How do I clear the clogged debris causing the water to constantly run? Culligan told me that the Faucet/Air gap is clogged. Need to dislodge the debris.
Normally when it leaks out the weep hole the drain line is plugged under the sink....turn off the ro to where it's not making water, disconnect the drain hose and flush it out....make sure the adapter that's connected to the drain pipe is still lined up with the hole if it was moved the water can't get to the drain.
Mar 17, 2009 | Culligan Under Sink Water Filter
Culligan Under Sink Water Filter Logo
1,973 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
