Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
Model No. E23CS75DSS4 SER: 4A61408938 MANUFACTURED: 03/2006 IN CANADA about once a week there is a small pool of water on the floor next to the left front side. Is there an evaporation tray that may be off level that is causing the water to pour onto the floor when it starts to fill (it is worse when the weather is warmer)
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: fridge is freezing on the
Freezer drain is plugged. Defrost the freezer and clear the drain line inside the freezer and in back where it exits the cabinet.
Posted on Jun 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: Water leak front left corner of freezer.
Your defrost drain line in the freezer is frozen closed.
You must turn off the fridge.
Remove the visible ice.
Use a hair dryer at the drain opening in the lower back of the freezer to melt the drain line ice.
Posted on Mar 11, 2009
localwonder
  • 6784 Answers
SOURCE: kelvinator frost free fridge leaking, pooling
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Jan 06, 2010
Testimonial: "Thankyou so much for such a quick reply to an Australian, can't ask for better service! I will try your suggestions which make perfect sense."
woodchuck789
  • 4070 Answers
SOURCE: Water pooling in bottom of
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on Jul 29, 2011
Pump wont turn on
make sure heat maintain is off if ok new pump
Apr 04, 2014 | Pentair Pool & Spa
Tip
Three tips for a cleaner pool
Having a pool at home can seem like a really awesome thing, but if its not cared for properly it can turn into a nuisance. There are a few small things that you can do on a weekly basis that will keep your pool clean and fun to play in. But keeping it clean can be very time consuming and physically taxing.
In movies you always see the pool boy skimming the top of the water of a pool with a long pole with a net on the end. What this does is it catches all the leaves and other stuff floating in the water. You will want to do this fairly often because when you leave stuff floating in the pool they will sink and then become close to impossible to get out and wreak havoc on your circulation system.
In addition to build up of leaves or branches from trees around the pool there will also be build up of chemicals that will make the water not be clear. To get rid of the chemical build up you are going to want to vacuum the pool. Whenever you vacuum make sure that your check the filters and clean them if you have to, for a clean pool you should vacuum once a week.
Once you have skimmed and vacuumed you are almost done! To make sure that you don't get algae build up you want to scrub the sides and floor of the pool. What you use to scrub the pool is dependent on what your pool is made out of. If the walls are plaster lined concrete you will want to use a stiff brush while for fiberglass you will want to use a softer brush so you don't ruin the walls.
on Jan 16, 2014 | Pool & Spa
Tip
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
Model No. DU850SWPU3 AND SER. FT 4101406 TYPE 280-0. When cycle is complete and in off position the dishwasher fills with water. I find the bottom of the dishwasher standing full of water when I get...
If by turning the wall switch off, and only then it stops comming in, it means the board is faulty. There is a leak in the electronic system allowing to solonoid to stay partially open. Strangs that it doesnt flow onto the floor.
Aug 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Have put 280 lbs of salt in my 9300 gaoole pool and still getting the low salt light. What is the next step? Just set up the pool last week but the chlorine converter is from late last year. It did not...
By my calculations you are about 50 lbs over the requirement. Which code are you getting? I'm guessing code 91. Have you removed and cleaned the electrolytic cell from the chlorinator? I get lots of calcium on mine from hard water from the well requiring a cleaning at least once per week. If you get this working and get a warning that you now have too much salt you'll need to drain off water and re-add to get the salt content correct.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
CAN U PLEASE TELL ME THE AGE OF THIS DRYER PLEASE 110 C60952990 SER # MJ4701614 THANX LEE
The manufacture date of the appliance is determined by the serial number. The following link explains how to determine the date on a Whirlpool manufactured appliance:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
According to the instructions, your dryer was manufactured in the 47th week of 1999, which would be in the month of November.
If you have questions, please let me know. I hope this helps you.
NOTE: Your Kenmore is manufactured by Whirlpool. The "110" prefix in the model number is the Whirlpool manufacturer code.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool washer age
Your washer was manufactured in March of 1993. The manufacture date is determined by the Serial Number. The second letter "C" represents the YEAR of manufacture. The first two numbers "14" represent the WEEK it was manufactured. The 14th week puts the manufacturing in late March. I hope this helps you.
Sep 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Model # TBX18TRBR large puddling leak on floor, think has to do with defroster messing up?? A GE refrigator serial # HG539639
I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Aug 22, 2009 | GE Refrigerators
Water leaking into the refrigerator
Hi, You have a drain plugged in the frezer. Your model # doesn't come up but what you need to do is remove the rear anel in the freezer and clear the ice. If the floor of the freezer has two screws holding it, remove it as well.
Please check the model# again and I can assist you further. There is an after market deat transfer strip you might need to add to prevent this from reaccuring.
Thanks
Vic
May 17, 2009 | Refrigerators
Water on rear floorboards
Under the car are drainvalves in the rockers.
these are small slits with a rubber valve in it, located just before the rear wheel and after the front wheel.
These are stuck, You can open them up by just putting You finger or a screwdriver in there.
I had the same problem, causes water and bad smell in Your car.
This is common by these types of convertibles, and caused by dirt washed in there from rain etc.
No big deal to solve.
Greetz
Gerrit Canada
Apr 07, 2009 | 1999 Chrysler Sebring
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven&#39;t got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren&#39;t any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
71 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
