Question about Boating
Stalls in inital take off
I have a 1982 90hp everude outboard when i try to take give it power it stalls. one up and running does fine.
I think I need to adjust carbs, how do I do this on this particular model?
  • 10,865 Answers
Hi. Replace the fuel line inside the motor, the fuel line to the tank and then get a bottle of a fuel additive called seafoam to clean out the engine. Also check the plugs and replace them if necessary.. This routine usually works. J.
Posted on Aug 01, 2010
Mercury outboard 3.5 motor stalls
not sure here as i normally answer car questions but if this engine is of the new generation and its all electronic then it has to be plugged in to locate the fault .My outboard was playing up like this with loss of power and the dealer wanted a small fortune to repair the pump which feed the fuel injection system so i took it apart and made a new valve for it out of a piece of fishing hook plastic wrapper and a bit of copper wire hook type thing i made and that was about 5 yrs ago and its still running fine
Apr 09, 2012 | Mercury Boating
My 1999 150 hp Johnson outboard skips at idle and started stalling at wake speeds. Was running fine until I tried it out for first time this year.
Fuel mix is a common cause of this kind of performance. Take special care to follow the manufactures instructions on fuel mix, most modern outboards run on100 to 1 while it is easy to continue an older mix like 50 or 33 to 1. Sometimes the mix is written on the engine cowl.
Cheers, Timo
Apr 21, 2010 | Boating
Mariner 25hp 2stroke outboard. runs fine when
With what you said.get the water pump done.A little bit of rubber is cheaper than metal.If the motor has a few years on it,the pump does need to be replaced.If the motor overheated after a few minutes,the pump needs replacing now.Yours sounds like it's on it's way out.A bit of sand etc. can do a fair bit.Hope this helps
Sep 09, 2009 | Boating
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Problem with are 2001 everude boat motor model# 9.9eidevl 45ic
The fuel line priming bulb acts as a check valvue. The bulb is more than likley bad. Cheap to replace.
Apr 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
154 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
