Question about Whirlpool Washing Machines
The rinse cyle is not working,it is spinning but the water is not coming out and it is not reaching the off cycle. Do I have to pay for this service? Am I entitled to the "Limited Time: Get 7-day Free Expert Support"? If yes then I agree to the Terms of Use
  • 4,354 Answers
Look for hoses reversed. Common issue, not apparent until someone manually turns off hot water, which is connected to cold port. Cold port is used for rinse.
Posted on Aug 01, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Washer stops agitating durning the rinse cyle, but timer keeps going. Also won't wont spin the water out on the rinse cycle. Wash and spin work just fine. This problem is the same on all three cycles.
I suggest you replace the control box. I need Mgfr & model # to find the part number for you. The replacement steps are more mechanical than electrical. Oh! make sure you UNPLUG unit before starting repair.
Feb 11, 2010 | Washing Machines
Spins during wash and rinse cyle, but not enough for the water to spin out
is it overloaded take out a third of the clothes ad redew the spin cycle see if this works
Nov 29, 2009 | Cars & Trucks
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Mav7200-57-58
The timer itself is bad, replace and wala! Timer Part Number: PT756240 Made by MAYTAG http://www.partstap.com/partsearch/model.aspx?model_id=47859 $70.22 + S&H
Sep 16, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
29 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
