Question about Whirlpool GHW9150 Front Load Washer
The control locked light is on and the washer won't start or do anything.
    President:
  • 949 Answers
Try pressing the "End of Cycle Signal" button for 4 seconds. This should release the control lock. If it does not then you have an issue with one of the controls and service may need to be run. Let me know if you have questions.
Thanks!
Posted on Aug 01, 2010
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
MIne Whirlpool duet is having probloms please help me with it!
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Washer will not start. Start button flashes but lid is not locked
If the lid lock light is flashing, that is an error. If the lid doesnt lock it won't do anything. There is a diagnostic test that you could do to prove it if you are good with electronics and ohm meters. Most tecks would probably tell you to replace the lid lock assembly. That is probably the cheapest part. The only problem is that without the diagnostis test it could be somthing else. But first check to see that the wire that comes from the lock is securely plugged into the control board.
Oct 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The locked light stays on but the top load door is not locked, and the washer will not start. I have unplugged the washer but still the cycle will not start.
What is your model type a FAV6800A or FAV9800A?
Are you up to troubleshooting the issue? We would need to see if the Left or Right hand lid lock is signaling the Control Board incorrectly. This could involve using a DVM to measure +12 VDC signaling from the Lid Locks to the Control Board.
A power Cycle of the Control Board won
Feb 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer locked. door lock light blinking. start button light on. won't do anything.
IT IS POSSIBLE YOU HAVE A DEFECTIVE DOOR LOCK OR CONTROL BOARD. CHECK YOU OWNERS MANUAL TOO SEE IF YOUR WASHER HAS A MANUAL RELEASE SO YOU CAN OPEN YOUR DOOR. USUALLY YOU CAN ACCESS A MANUAL RELEASE BY REMOVING THE FRONT BOTTOM PANEL AND REACHING UP UNDER THE DOOR LOCK AND FINDING A PLASTIC PULL PIECE WHICH YOU CALL PULL AND UNLOCK THE DOOR. MAKE SURE YOU UNPLUG THE WASHER FIRST. CHECK THE DOOR LOCK MECHANISMS TO SEE IF ANYTHING IS BROKEN AFTER YOU GET THE DOOR OPEN.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
115 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
