Question about Craftsman 25cc Gas Line Trimmer
Weed eater wont start
Need fuel line diagrahm for weed eaters
  • Craftsman Master
  • 1,631 Answers
If you haven't changed fuel filter in awhile, do that as well.
look here...
Posted on May 19, 2015
  • 2,510 Answers
Assuming that your machine has a bulb type primer, it would normally only have two fuel lines, one is the supply and the other the return. With fuel in the tank, the return line should be above the fuel level while the supply line normally has a weighted filter attached to it. Pump the bulb, if fuel comes out of the pipe above the fuel level you are ok, if bubbles come out of the filter/weight, swap the tubes on the carb and carry out the test again.
Posted on Jan 14, 2011
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed eater fb25 25cc gas blower wont start
    change the spark plug--put fresh fuel in gas tank 89 octane mix
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
    Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
    Weed Eater GTI 19T
    If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
    Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
    change the fuel lines over on the carby
    you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
    Mar 12, 2017 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    Powerpro 17" McCollich weed eater
    hey harry the float inside the carb is stuck i would suggest rebuilding the carb
    Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    My Troy Built weed eater wont keep string going.
    troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
    May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Fuel hoses routed wrong on weed eater fuel tank
    http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
    Apr 04, 2009 | Garden
    Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
    Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
    Craftsman 25cc Gas Line Trimmer Logo
    448 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
