Question about Juster AC-691 Computer Speakers
What is the power input to a Pro Juster DC-691P?
2 Suggested Answers
t_aforrester
  • 93 Answers
SOURCE: need spec and power supply
Speakers (External, Powered), (Adapter, 9V, -Outer, +Center) Juster DC-691PASpeakers (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PA
Posted on Sep 09, 2010
Where do I get a power cord for a euro-pro mod l 9130C
When buying such power adapters, you typically need to watch for:
  1. DC voltage - in this case 19V. This needs to be the same.
  2. DC amp rating - since your adapter is rated at 6.32A, you need a replacement that is rated at a minimum of 6.32A, but there's no harm in going higher. Your device will only draw what it needs.
  3. DC plug polarity. Most are center positive, as is yours.
  4. DC plug size. This is defined by inner and outer diameter. In your case, it's 5.5mmx2.5mm
  5. Input voltage. You haven't mentioned your region, but it's a good idea to get international power adapters that accept 100-240V.
You've stated that you prefer to use the existing power cord, but this is an unnecessary constraint - it's better to use the power cord that comes with the replacement adapter
Sep 20, 2017 | Euro-Pro Sewing Machines
My dc691p speakers require 9 vold dc. Will it do any harm to use a 19 volt dc
yes, your speakers will be damaged. do not connect 19 volts to a 9 volt device. go to walmart or radioshack and purchase the correct power supply.
Mar 01, 2014 | Juster AC-691 Computer Speakers
Need spec and power supply for this set of speakers "Juster DC-691P"
Sep 08, 2010 | Juster AC-691 Computer Speakers
What power lead do I need for Juster 691 computer speakers
the power lead is 110/220 from outlet and the power of the speaker are 3watt 1ohm impedance o.1 distortion
JUSTER DC-691PA SPEAKERS USE AN AC WALL ADAPTER. DO YOU KNOW THE POWER REQUIRMENTS FOR THIS SYSTEM?
Computer Speakers Juster (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PAYZNJ891701998
Aug 30, 2010 | Audio Players & Recorders
What is the power adapter needed for the Pro Juster 691Pa speaker system?
Aug 22, 2010 | Juster AC-691 Computer Speakers
What is the output voltage on the adapter for justin 691p speakers
Aug 11, 2010 | Juster AC-691 Computer Speakers
What dc output voltage does it take for my juster 692p
From any port on a powered USB hub, you can draw up to 500 milliamps at 5 volts. This gives two and a half watts to play with; the peak draw of the SP-692p probably won't exceed two watts.
Hope this initial info/idea helps.
Let me know for any clarifications.
Apr 06, 2010 | Juster AC-691 Computer Speakers
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
Juster AC-691 Computer Speakers Logo
96 people viewed this question
Top Juster Audio Players & Recorders Experts
Victorman
Victorman
Rick
Vladimir Frolov
Are you a Juster Audio Player and Recorder Expert? Answer questions, earn points and help others
