Question about Rule 1800 H53SP-24 Swimming Pool Cover Pump
CAN I USE MY POOL COVER PUMP WITHOUT THE INTERNAL FILTER TO GET RID OF BUGS AND SLUDGE?
  • 990 Answers
No you will probally plug the pump and may hurt it when that happens.
Posted on Aug 01, 2010
Dirt comes back in pool after vac even though I backwash
take filter apart see if the cloth grids are torn if so replace that will get rid of redepositing
Jun 26, 2014 | Hayward EC-40 DE Pool Filter with pump
Sand getting in pool
check laterals inside filter if broken replace or put fine mess over them until you can replace old sand will go through the holes because it breaks down in size
Jun 21, 2014 | Sta Rite 21 Sand Filter System with 3/4 Hp...
2000 plymout neon how to replace water pump
Get rid of that "Toy" and get a real pump.
You will be so much more pleased & happier with a Real Pool Pump setup.
Call your local pool dealer and get a good upgrade.
Sep 14, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Pressure doesn't last & seems to blow out cloudy, dingy water
if you are on city treated water, sand will last aprox. 7 years, if on well water typically 3 - 5 years. so yes, could be a sand issue. also, double check that the there is no water trickling out the backwash / drain outlet of the filter, this could indicate that the diverter valve gasket (spider gasket) could be worn and cause sand from the filter to flow to the pool. this is a common problem if you move the position selector often with the pump still running - the pump should always be off when moving the handle. good luck!
Jun 01, 2010 | Hayward SAND FILTER, PRO SERIES
We do not know where the air filter valves are
Air filter?
Remove the strainer basket cover ... fill with water ... check the gasket ... replace if questionable ... close the cover and SNUG the top down. Start the pump ... it should run just fine.
If you are sucking air, tighten the strainer basket cover a little.
Still sucking air? You will have to find the air leak. You might plug the leak with plumbers putty.
May 29, 2010 | Jacuzzi Cyget In Ground Pool Pumps
MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V: I'm a new pool user and can't get the pump to prim...
WELL LET ME SAVE YOU FROM THAT JACCUZI .. GET RID OF IT, GET A STA-RITE DURA GLASS.. PARTS ARE HARD TO FIND FOR JACCUZI.. BUT IF YOU LIKE PAIN, YOU MIGHT GET THE LID O-RING AND THE SHAFT SEAL FROM YOUR LOCAL POOL STORE. ASK HOW TO REPLACE THE SEAL AND DO IT RIGHT.. PRIME PUMP AFTER A REPAIR! VOTE IF I WAS HELP ...J
May 17, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a 15 x 4 heritage pool. I am having
It sounds like you have a clog in your pump impeller, If you go into the front of the pump with the basket removed you can get into this with a long nose plier.
Oct 10, 2009 | Heritage Pool and Cover Pump
Hi, bottom of pool is clean that morning, I run the pump and at the end of the day there will be quite a bit of dirt and what looks like tiny bugs on the bottom. It's like the pump is passing stuff right...
It may be the filter unit. If it's a DE filter, it's possible that one of the cartridges inside has a hole, rip, tear and the debris is getting back in... is it cloudy at all? Make sure that the diverter top is put back on in the exact same location as you had it before...
Aug 02, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Rule 1800 H53SP-24 Swimming Pool Cover Pump Logo
95 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
