Question about Honda Garden
Honda hrb 216 shuts off after bout 15 min after sitting for a while....then shuts off every couple min....something is effecting gas flow it appears.....anybody had this issue plls advise...thx
  • Honda Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 15, 2010
2007 vulcan 1600 classic wont stay running
i rekon when ya changed the tank over it had rust in it and has contaminated yer fuel lines, pump and carby with bits o rust. So rip off the tank, lines,pump and carby and give em all a good clean, reassemble and yer all good to go.
Nov 05, 2017 | Motorcycles
92 accord starts and then shuts off
If the battery was dead/charged/replaced the vehicle may have to go through an idle relearn procedure. Get it running and try to keep it running by feathering gas pedal until it reaches operating temp. Ideally you want to be able to take it for a drive for the Honda PGM system to relearn
Apr 07, 2015 | 1992 Honda Accord
How to replace drive cable on honda hrb 216 tda
Disconnect both ends, attach new cable. Google model number parts for illustration.
May 08, 2013 | Honda Garden
Lx 4 cyl carbuerated
Could be a vapor-lock problem where the gas in the carb is boiling out.
You could try carb cleaner sprayed into the air cleaner to verify.
Could also be the fuel pump relay if equipped.
Aug 24, 2012 | 1987 Honda Accord
1981 Honda CT110 trail. Runs perfect for about 5 miles then dies. Starts a couple times each time slowly idling down until it dies then it will not start again for until it sits for an hour or so. I...
It sounds like you still have dirt floating around. What did you coat the tank with? I used POR-15 with great results. Install a gas filter that you can see through and see if you are still getting dirt from the tank. Check the new carb for dirt. It sounds like something is somewhat plugged which allows gas to slowly fill your carb after it sits. But this clog is what causes your bike to stop after 5 miles. Does your tank have a shutoff valve? Run a line from the valve to a jar and see how well the gas flows. The shutoff valves usually have a screen....check it for dirt.
Nov 26, 2010 | 1982 Honda VT 250 F
Honda HRB 216 Lawn Mower Manual
Sure you don't mean HRR? A number of models can by downloaded from the HRR from:
http://lawnandgarden.manualsonline.com/manuals/
Search using the Lawn and Garden Product Manual Finder which can be found on the left side.
Oct 02, 2010 | Garden
I have a toro LX 500 Riding Mower with Kohler Courage 22 motor. I was cutting grass and it started hesitating and eventually shut off. It will start but only runs for a bout 30 sec to 1 min before it shuts...
When you had the fuel filter off, did gas flow freely from the hose? Sounds like maybe the tank has dirt in it blocking the fuel line. Other than that, maybe there is dirt in the carburetor bowl.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Toro Lawn Mower With Toro Power Tools
MY GX 240 starts fine runs great any where from 30
Can your gas tank breathe? Is your fuel filter clogged? Might there be something in the tank that would obstruct the flow of fuel?
Check the tank by loosening the top to allow air to enter.
Let me know what happens
a
Sep 23, 2009 | Honda 8 HP Engine
Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Apr 29, 2009 | Garden
Gas go's on then shut off
Check the exhaust for good air flow.
Remove the rear exhaust vent and run the dryer.
If that corrects the problem repair the vent blockage.
If it does not correct the problem replace the gas valve coils.
Mar 12, 2009 | Whirlpool Dryers
Garden Logo
253 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
