Question about Samsung RS2630SH Side by Side Refrigerator
Refrigerator area is freezing, frost forms in the back (not visible) Visible only if you take it apart. temperature goes from 34 to 46 in temperature on a RS257BARB. We took it apart and defrosted back area and it began to work about 1 week 1/2 and it did it again. Fan is working.
    President:
  • 2,468 Answers
The defrost heater under the evaporator in the freezer or if in the refrige section which is a heater grid in front of the evaporator is bad,or the defrost thermostats in either case near the evaps could be bad,or the adaptive defrost controls in the refrige area could be bad too
Posted on Aug 01, 2010
Sub-Zero Model 532. The refrigerator section is freezing up. I've vacuumed the condenser area but it's still happening. Adjusting the temperature doesn't help, either.
The defrost cycle is not working there should be defrost board also should check the defrost bimetal and check heater
May 10, 2016 | Frost Refrigerators
I have some frost on back wall and some food freezes now and then.
Assumeing you are saying frost on the back wall of the refigirator, I would increase the temperature for the refrigirator area. If that does not help you may have problems with the defrost system.
Apr 14, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Why is my subzero refrigerator (model 550 o/u) leaking?
Frost build up in that area is common, it is where the compressed gas leaves the compressor on its way to the evaporator inside the unit. The putty is put there on purpose during manufacture to insulate. Things aren't helped if you have a moist warm kitchen as the air condenses at that spot and freezes. If the fridge is in reasonable condition elsewhere and you don't wish to buy another there are a few things you can do. The area with the frost can be fixed with a can of expandable foam, or foam insulation cut to size to fully cover and insulate that area. Any condensation of the back can be fixed by covering with thin polystyrene sheet which comes in a roll. cut to size and stick with contact adhesive in blobs.
Your icemaker won't make any difference to the problem. Don't forget the water supply hose should be changed every 10 years.
If you do decide to change, one benefit is cheaper running costs. Improvements are being made all the time. Having said that, SubZero are a premium make.
Mar 10, 2017 | Sub-Zero Refrigerators
Side by side thermostat set low seems like it runs a lot more than it use to freezer and fridge are boyh cold
Check your coils underneath the fridge to be sure they are clean.
Check your condensor fan (bottom rear of fridge) to make sure it is blowing air freely.
Make sure you have a good supply in the freezer, All of your cooling comes from the freezer section and a mostly empty freezer will result in more frequent running as ther is not enough stock to help maintian and hold freezing temperatures.
Check your freezer section to make sure there is no visible frost on the back wall of the freezer (down low on the panels behind and slightly above the lowest freezer basket. If you see frost starting to develop it means you have a defrost issue starting and will want to adress it rather quickly. Either a problem with the defrost control board (inside fridge/freezer control compartment) or the defrost thermostat (behind the freezer back panel on top of the evaporator coils).
Hopefully this helps!
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost free fridge freezing up..
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 11, 2009 | Refrigerators
GE fridge - too cold
$00.00... I think
Make sure no vents are blocked
(or frosted over)...
If you have a freezer (or friend with one)
& an ice chest... Parcel out your food for a
three day open air defrost...
Room fans would be great...
OPEN THE DOORS.
Use NO HEAT...
as the soft plastics inside your refrigerator
can be EASILY DAMAGED.
An errant pizza box or ice cube can cause air intrusion... significant frost (ultimately an ICE BLOCK). A total defrost
is the VERY BEST FIRST STEP...
HOWEVER... if the frost recurs
you might have a DEFROST FAILURE
(Totally different symptoms
(Not FREE... but also easy to fix)).
Here daily... FREE (just for this purpose)...
We can do this...
Carnac the Magnificent
Nov 09, 2017 | GE PSS25SGN Side by Side Refrigerator
Freezing all veggs in fridge
The temperature in the fridge should be from 32-40 degrees. Go buy a little fridge thermometer and place it in there. They are cheap and you can pick one up many places. I leave mine in year round. Then adjust your settings accordingly. Don't do anything drastic adjust, then check in twenty-four hours then readjust if necessary to reach the proper temperature. No visible frost inside the unit anywhere right?
May 21, 2009 | Amana ATB2135HR Top Freezer Refrigerator
Water drip from freezer to refrigerator
Defrost drain line in the freezer is frozen shut.
Remove the freezer panels.bottom and back panels.
Remove the visible ice.
Take a hair dryer and thaw the drain hole in the center rear drain trough.
Mar 12, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Hotpoint FFL49X Fridge compartment
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Aug 14, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
158 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
