Question about AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34
First stage of my 2 speed hot tub ao smith pump doesnt work electrcian says switch is not lined up right?
  • AO Smith Master
  • 1,384 Answers
These are a hard motor - pump to work on. i would take it to your local pool pump motor repair guy who has free motor testing , un plug the motor from the control box not at the motor, if you do take pictures or make a diagram of each wires place ! if you hook it up wrong you can BURN THE MOTOR UP AND THERE IS NO FIX'N IT. sept for a new motor $$$ yuk .take the pluming lose and leave the pump on the motor.... good luck .. hope i was a little help if so please leave feedback .. Jay THE PPMRG FLORIDA
Posted on Aug 03, 2010
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
Replaced the seal and impellar, now pump is getting hot and turning off? any suggestions
SOUNDS LIKE YOU GOT THE WRONG IMPELLER, THE ONE YOU GOT IS FOR A BIGGER MOTOR.. THESE IMPELLERS CAN BE A PAIN TO ID, OR EVEN FIND .. TRY THE IMPELLER FOR A 1HP. I BET IT WILL WORK JUST FINE .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FL ..
Feb 27, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Leaky 4 HP hot tub pump seal AO SMITH motor, pump
If you have removed the impeller this is what you need.
Part number for your shaft seal is : 37400-0028s
Here is a link to the manual on how to install / remove this seal on this pump:
http://www.hottubs.com/content/pdf/Sta-Rite_Dura-Jet_S377(9-12-03).pdf
Refer to page 9.
This seal can be purchased anywhere on the internet. Just do a google search with only the part number. Many suppliers will come up. If you have trouble, I have a few and can make an E-bay sale for one.
Nov 15, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the...
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
May 31, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34 Logo
263 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
