HDMI Cables Do HDMI cabes support the most advanced surround sound? Is the most advanced 7.1 Dolby?
2 Suggested Answers
SOURCE: RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Posted on Dec 28, 2008
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Jun 17, 2009 | Vizio SV470XVT 47 in. LCD TV
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
PS3 hdmi Audio problem Crackling Sounds
I CHANGED THE AUDIO SETTING UNDER HDMI FROM AUTO TO MANUAL AND I REMOVED DOLBY 5.1 FROM SELECTIONS.LEFT THE OTHER 2 SELECTIONS THAT WERE ALREADY SELECTED FROM AUTO SET FOR HDMI I HAVE NOT HAD AUDIO PROBLEMS SINCE.
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
Yamaha RX-V663 wont play rear surround
The best way to get Dolby sound working is to connect the components using the optical links.
As long as you are using PCM the Dolby sounds will never get to your system. It's switching the Dolby sound off as soon as it detects PCM. I think the only way you will get Dolby on is via a optical cable which should let you have bitstream.
Mar 12, 2017 | Audio Players & Recorders
REGENT MODEL HT391 SURROUND SYSTEM
i need to know how to hook up my home theater to my TV and Dvd.
Oct 04, 2008 | Durabrand HT-3915 System
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
No surround sound when watching TV
hdmi can only pass pcm 2.0 digital for the separate cables you may try to switch them to another output from the monitor to the receiver or if you can get your hands on a spd-if cable (one single fiberoptic cable that will go as high as 5.1 dolby surround)
Dec 27, 2007 | Televison & Video
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Nov 24, 2007 | Onkyo TX-SR605 Receiver
 Grubhead
Grubhead
