Can't locate windows system or drive D - Computers & Internet
  • 4,924 Answers
Im not sure if I understood it right ...but if you are saying that you can not locate the my computer folder just go to start and press My computer line ..and you will end up in the same place like from the desktop ....If you want to place again the my computer on the desktop...just right click on the desktop ..choose properties..than desktop ...In there it has a feature called customize desktop ...and all you have to do is to click on the windows item you need on desktop ...or ..if this seam too hard ..just go to start ..locate my computer link ...click right on it ..and choose send to desktop ..
Posted on Aug 01, 2010
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Tip
Performance tip: Do you have more that 1 hard drive in your Computer?
If you have 2 or more hard drives in your computer you can increase performance by moving your swap file (an old operating system trick to artificially create more memory space used by Windows, also called virtual memory or page file).
In XP(Other Windows OS's are similar):
Start Button -> Control Panel -> double click System icon.
-In the System Properties Box select Advanced.
-In the Advanced tab select settings located under Performance.
-In the new box select the Advanced tab.
-In the Advanced section select change located under Virtual Memory.
-Under Drives select the drive that has have your Operating System in and choose No paging file, click on set.
-Next select any other drive and select System Managed size, click on set. Click OK,OK,OK OK to restart.
Usually the bigger the drive the faster. The faster the better.
Windows can now access the swap file on 1 drive as it accesses data on the other instead of waiting for data from 1 drive.
This tip applies if you have 2 physical hard disk drives, not 2 drives in 1 disk.
If you are a gamer get another disk and do this trick.
on Jan 08, 2010 | Computers & Internet
How do I remove the 'write-protection' on my DANE-ELEC 4GB flash drive?
if you are using windows as your operating system then follow these steps below
1.click on start 2.click on run and then write regedit or regedit32 in run window 3.next it will open a new window's which is Registry editor locate HkEY_LOCAL_MACHINE\SYSTEM\CURRENT CONTROL SET\CONTROL 4. Locate sub key storage device policies and then locate Dword value Write protect for disabling write protection you have to set value to 0 if it's 1 there !!!!
Sep 21, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
How can i download a music .save to my usb?
1. 1. Connect your USB Flash drive to your computer.You can do this by locating an unused USB port on your computer. 2. Locate the my computer icon on your desktop,provided you are running one of the various Windows operating systems. Doubleclick the my computer icon. You will see a drive labeled as removable drive orflash drive. Double click on the drive. Leavethis window open, proceed to next step. 3. 3. Locate the music files that you havedownloaded/save to your computer. Usually the default location will be "My Music" folder under "MyDocuments". Open the folder that you have downloaded/saved your music in. 4. 4. Highlight the music file and right click. Pickthe copy option. Next go back to the window you opened for you flash drive instep one. Right click in this window and click paste. You should now see yourmusic file in this window.
Jul 17, 2011 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
We have a TEAC FD-05PUB external floppy drive that we are unable to run - system is Windows xp - we can connect to other PCs and it works fine. Thought perhaps it was the drivers but unable to located any...
The USB Floppy Drive shouldn't require drivers under Windows XP (according to TEAC, here: http://goo.gl/BvTcV).
Make sure your Windows XP installation is completely up to date, as Windows Updates often contain driver updates as well as system updates. If this still doesn't work (or your system is already completely updated), there are some additional troubleshooting options here: http://support.microsoft.com/kb/283658.
May 03, 2011 | Teac FD-05PUB External Floppy Drive
Hi, am using Adobe photoshop cs4 extended. Recently when am opening the photoshop am getting the error message that "adobe photoshop cs4: photoshop.exe-entry point not found". and " the...
Which Operating System is running on your computer? If it's Windows XP, you need to delete a file with the name "dwmapi.dll" in the C: drive's System32 folder under Windows folder. If I am right, the problem might have started after installing Mozilla Firefox. The reason is a wrong driver of Windows Vista installed on Windows XP system.
The process is like this:
Open My Computer, then "C:" drive, and again "Windows", locate "System32" folder and again locate "dwmapi.dll" in the System32 folder and delete the "dwmapi.dll". That should definitely do the trick.
Good luck.
Thanks for using FixYa.
Nov 17, 2010 | Microsoft Computers & Internet
1304 error when trying to install microsoft office student 2007
To resolve this behavior, use the following methods.
Method
: Re-Register the Windows Installer
To re-register the Windows Installer, verify the location of the Msiexec.exe file on your hard disk and in the Windows Registry, and then re-register the Windows Installer. To do so:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Verify the location of the Msiexec.exe file on your hard disk. To do so:
Click Start, and then click Search.
Click All files and folders.
In the File name box, type msiexec.exe, and then click Search.
In the search results, make a note of the location of the Msiexec.exe file.
The location of the Msiexec.exe file should be similar to the following example, where Drive is the drive where Windows is installed, and %Windir% is the folder where Windows is installed:
Drive:\%Windir%\System32
An example of this is C:\Windows\System32.
Note In Microsoft Windows 98-based computers, the Msiexec.exe file is located in the Drive:\%Windir%\System folder.
On the File menu, click Close.
Verify the location of the Msiexec.exe file in the Windows Registry. To do so:
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\MSIServer
In the right pane, double-click ImagePath.
In the Edit String dialog box, make sure that the string in the Value data box contains the correct path of the Msiexec.exe file on your hard disk that you determined earlier in step 1.
For example, if the Msiexec.exe file is located in the Drive:\Windows\System32 folder on your hard disk, the correct path of the Msiexec.exe file in the Value data box is the following path, where Drive is the drive where Windows is installed:
Drive:\Windows\System32\Msiexec.exe /V
If the Value data box does not contain the correct path, make the appropriate changes to correct the path, and then click OK.
Quit Registry Editor.
Start your computer in safe mode, and then register the Msiexec.exe file. To do so:
Shut down, and then restart your computer.
Press F8 after you receive the following message:
Please select the operating system to start
On the Windows Advanced Option menu, use the arrow keys to select Safe Mode, and then press ENTER.
If you use a dual-boot or multiple-boot computer, select the appropriate operating system from the list that is displayed, and then press ENTER.
Log on to the computer.
In the Open box, type the following line, and then click OK:
msiexec /regserver
Shut down, and then restart your computer in standard mode.
If the issue persists and you still receive the error message that is described earlier in the "Symptoms" section, follow the steps in Method 2.
Method 2: Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer files, and then reinstall the Windows Installer. To do so:
In the Open box, type cmd, and then click OK.
At the command prompt, type the following line, and then press ENTER, where Drive is the drive where Windows is installed and where %Windir% is the folder where Windows is installed:
attrib -r -s -h drive:\%Windir%\system32\dllcache
For example, type
attrib -r -s -h c:\windows\\system32\dllcache
At the command prompt, type exit, and then press ENTER.
Restart your computer.
Update the Windows Installer files on your hard disk to the latest version. __________________
Feb 22, 2010 | Microsoft Office Professional 2007 Full...
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
Windows XP , system goes to sleep immediately after booting.
CHANGE THE CD OS IF YOU HAVE ANY AVAILABLE SOME FILE NEEDED IF YOU KNOW HOW LOCATE THAT FILE DOES'NT MATTER BUT THE PROBLEM IS YOU DONT KNOW HOW LOCATE..
PROBLEM FROM THE CD INSTALLER
Jun 25, 2009 | Microsoft Windows XP Professional
Where is the /System32 folder physically located on the drive?
Hi there.
This is the path >>>>>> c:/windows/system32....
So, click on "my computer", you will see "local disk c", click on that, if it says "these folders are hidden" click on "show files". Then click on the "windows" folder, in that folder you will find "system32" folder.
Thanks for choosing FixYa!!
Jun 12, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
