Question about Howse Rough Cut Mower 3Point Category 1 5ft Length
Cant get standard wrench or socket between saucer and mower deck on 3pt Howse rotary cutter. is there a special wrench made?
  • 10,865 Answers
Yes there is a special wrench.
Posted on Aug 01, 2010
MY WIFE WAS MOWING LASTNIGHT AND THE MOWER DECK QUIT.NO BROKEN BELTS. I'M AT A LOSS
Petrol? Electric? Make? Model? Size? Rotary? Cutter? String?
May 17, 2018 | Garden
Were is the oil screw
Search Results
    1. Remove the dipstick, if equipped. Tilt the mower deck with the air filter or spark plug side up, and position some newspaper and an oil pan or jug beneath the mower. Use a 3/8" drive socket wrench and extension (no socket) to turn the plug counter clockwise (see photo at right), allowing the old oil to drain.
      How to Change Oil ' Briggs & Stratton
      https://www.briggsandstratton.com/...mower.../how-to-cha... Briggs & Stratton
Oct 24, 2015 | Garden
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
Need part for John Deere 217 3pt hitch 5' rotary cutter
sir go to the tractorhouse.com and order what u want and they will serve u.
thank u...
Nov 23, 2012 | Garden
Craftsman 42", 18.5 lawn tractor: blades are hitting in the mower deck. Blades are new and deck is balanced. Is it wear on the Mandrel - Shaft? Mandrel bearing?
Oh boy!!! Welcome to the craftsman worst design of their mower decks CHEAP!!!!! I had to replace my mandrel on the right side, side where the grass shoots out several times!! Cheap aluminum casting ****, one or more of your ears on the mandrel probably snapped, if you have an air wrench they are not too bad to replace, the screws that go into the mandrel are self threading and is easier to work on with air wrench but can be done with socket set, hope this helps!!!! good luck!
Aug 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
How can I adjust the blades
deck is adjusted by 2 leveling bolts on each side at edge of frame....also hold deck up...should be 1/2...use a wrench....i take two sockets and line up with blade ends and lower deck to see which blade needs adjusting.
Jun 11, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Apr 04, 2009 | Garden
Howse Rough Cut Mower 3Point Category 1 5ft Length Logo
85 people viewed this question
Top Howse Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Howse Garden Expert? Answer questions, earn points and help others
