Question about Kenmore Refrigerators
The water feed to the ice maker is frozen - I can see that it is plugged with frozen water. I was able to get the frozen water out of the chute that leads to the ice maker but I can still see the ice plugging the water feed to the chute. I have a Kenmore side by side refrigerator model number 106.56586500.
    President:
  • 949 Answers
This usually means the water inlet valve that feeds the ice maker is bad. It can bypass a small amount of water and that water runs so slow that it freezes in the tube you are clearing.
The valve I am talking about is behind the frig on the bottom, it should be blue in color.
To clear the ice from the tube use hot water and a turkey baster, or a hair dryer.
The part number for the water valve is 4389177
Posted on Aug 01, 2010
Testimonial: "Thanks! That seems to have worked!"
  • 10,865 Answers
Hi, turn it off for an hour and then use a hair blow dryer to thaw it out. J.
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
The ice maker makes humming noise but is not making ice
Sounds to me like the water control solenoid has failed and is not opening to allow water to flow into the ice maker.
Jan 20, 2013 | Frigidaire GLRS267ZA Side by Side...
GE Refridge GSH25JFXBB Ice but no water
This is solution to frozen water 'plug' preventing water dispense but ice maker still making ice. I first tried a suggested fix from this site to just leave dispenser light on overnight. I added some aluminum foil sealed over the module with a little tape to hold in heat. By morning still no water dispensed BUT I escalated the suggested fix by 1.) placing a large mug of boiling water in the compartment behind the aluminum foil 'cover' heat seal and 2.) added a small bean bag heating/cooling pad [heated in microwave] to the ice chute in the door from the freezer side. After one change out of the two 'heat sources' (about 30 min)...viola! Water dispensing again; proving it was an ice plug in the water dispenser. NOTE: When first adding the heating bag to the ice chute in the door, I found that a good bit of frost had formed at the top of the ice chute, so it appears this problem arose when someone (maybe even me) didn't close the freezer door completely due to overcrowding in that section of the freezer pushing against the freezer section door.
May 02, 2012 | Refrigerators
The ice maker doesn't work. I can get cold water from the refrigerator so I assume that the line is not frozen. I just changed the water filter to see if that might help but it didn't.
Check the folllowing:
The end of the ice chute inside the freezer compartment that dumps into the ice tray - they can feeze and block water flow.
Remove the water chute and see if the water orifice is frozen. If so, it will block water flow. it can be thawed out with a hair dryer (carefully).
If no luck, look for a bad water valve or possible kink in the water line. This valve is usually located under the back of the fridge behind a cover.
If all ok, there could be an issue with the ice maker itself or on some units, a control circuit board.
Try unplugging the fridge, let it sit for at least 5 minutes and then plug it back in and see what happens.
Apr 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frozen water in ice tray
You do need to thaw the ice maker out completely. I always remove it but that may be more than you are up to. You can also try a hair dryer on it to thaw it out.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Feb 26, 2018 | Whirlpool GS6NBEXRB Side by Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker
My wife installed a new filter and didn't purge (AKA flush) it enough. As a result, my ice maker quit. Since there was air in the line, the water feed into the ice maker froze. You should check your water feed. In your freezer, look to the top right part of your ice maker. You will see a short (2 inches or so) black tube that feeds water into a piece a plastic on your ice maker that looks like a small cup. Squeeze the tube to see if frozen. If it is, there is probably also a frozen pool of water in the 'ice maker' cup. You can use a hairdryer but be very careful as you can melt the plastic. My service guy took out the ice maker and ran it under hot water. He used a small screw driver to get the ice out of the black hose. Removing the ice maker looked pretty easy. You can remove the ice maker door (it justs snaps out). the ice maker also just slides out. If you are not comfortable removing the wire connection, there's enough plat in the wire to allow you access to the frozen cup of water. You could pour hot water over the ice maker while it remains connected. When done, cut power to the entire frig for about a minute. This will reset the ice maker. Note that you may have a wait a few minutes to actually hear the ice maker fill with water since it has a timer mechanism.
Aug 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker won't work...water line frozen?
HOLLOW ICE FOLLOWED BY FROZEN WATER CHUTE ARE THE FIRST SIGNS THAT THE WATER INLET VAVLE IS OR HAS FAILED, IT CAN ALSO CAUSE DAMAGE TO THE ICEMAKER BY BURNING OUT THEN TIMING GEAR DUE TO INSUFFIENT WATER OR FLOODING IN ICEMAKER WITH TOO MUCH WATER
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Apr 29, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
218 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
