Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The switch to make the spin cycle stop when the washer is open is broke. The washwer will not go into the spin cycle even when the lid is closed. Please help. Michelle
  • Whirlpool Master
  • 3,361 Answers
You diagnosed your own problem.
Replace the lid switch.
Posted on Aug 01, 2010
Washer will fill with water and then pops the circuit breaker
see the causes:
t doesn't pump or spin
frozen puller+ belt broken replace
It pumps, but doesn't spin
lid swithc broker or open,motor coupler broken,belt broken, and clutch worn,drive motor defective,transmision not shifting properly,basket driven worn.
It spins only with the lid closed lid switch prevent the action to start.
see the diagram
Jun 19, 2012 | Washing Machines
Recently our LSQ8243H Washer stopped in the middle of the cycle. The first couple of times it happened all we had to do was open and close the lid and everything was fine. Now it stops and we have to...
Hi, I'd like to help diagnose your problem but I may need a bit more information. Based on what you stated, I assume you have a top loading WHR washer with an electromechanical timer... the kind that you turn and it clicks. Anyway, you stated that the washer stopped in the middle of the cycle and that simply opening and closing the lid would fix it for a while. I suspect that your lid safety switch may be cracked and isn't being actuated by the plunger on the lid. If this is the case, the washer would function properly until it reached the point in the cycle where it should spin. Then it would stop at that point in the cycle. This makes sense that opening and closing the lid might "fix" it for a while. Also, if the switch got bad enough that opening / closing the lid didn't work anymore, you could rotate the timer dial just past the spin area and the cycle would continue. Have you noticed the clothes are wetter at the end of the cycle?
Anyway, check the lid switch first and then repost if you rule it out.
Good luck.
Jan 18, 2011 | Whirlpool LSQ8243H
Washer will not go into the spin cycle
If the machine runs through everything and just stops full of water at the spin cycle your lid switch is probably bad. Its either located under the lid when you open it on the right hand side, or under the control heading. If its there just open the lid and listen for a clicking sound when you open and close, if you don't hear that the switch is broke.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Kenmore 23822 Top Load Washer
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
2242210 will not spin..wash cycle is fine
Could be several things, but the most common is the lid switch. The little plastic rod on the lid strikes it when the lid is closed. Make sure the switch is not broke. You should hear it click when the lid is closed. If not then it is definitely that.
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer wont spin
do you hear a clicking noise when you close the lid if not check the lid switch if so then check the coupler it is the plastic and rubber piece in between the motor and the transmission
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Will not drain after the wash cycle, will not enter the rinse cycle
It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
Aug 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer does not drain after the rinse cycle
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
May 31, 2008 | Whirlpool Washing Machines
Washer will not stop spinnig
You probably have a blocked pump. Pull it out and clear the obstructions- buttons, lint, etc
Jun 02, 2006 | GE WJSR2070B Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
55 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
